Home > Help Needed / General Tech Chat > Yet another thread size question...?
Si P
Member #: 912
North Yorkshire
Right guy's
Can't seem to find it listed. But it's the 2 bolt holes in front of the clutch slave cylinder location. Its were most people ( and myself ) mount their coil packs.
Looks UNC..?
But not to sure.
Si
shane
Member #: 1246
Lowestoft, Suffolk.
Without a pic i CAN ONLY GUESS its the holes above the starter? if so I think 5?16" UNC?
Shane
Si P
Member #: 912
North Yorkshire
Yep. That’s the fellows. Directly above the starter. Not used for anything apart from a mounting for the cable to feed the starter motor.
Mk1 coil mounting posts...
Yes, 5/16 UNC
Si P
Member #: 912
North Yorkshire
Thanks for confirming things.
I can now mount the coil pack and see if the thing will start.
Thanks again
Si
Edited by Si P on 31st Oct, 2007.
If you are feeling rough and own a tap M8 will do as well!
Si P
Member #: 912
North Yorkshire
The thought did cross my mind. *evil*
Sacrilege!
No metric shit should ever be on a Mini. Get a 3/8UNC tap.
3/8 UNC?
Rather large for mounting into those cast bosses Vegard.
That's what the slave is mounted in, aren't those bosses the same size OD?
Don't think so.
Ok, then I suggest helicoil. I just loathe to have a mix and match metric/imperial car. Yes Mark, I'm talking to you!
miniminor63
Member #: 672
The oversills police
Oslo, Norway
why use a helicoil? why not just use the 5/16 UNC thats already there? has he mentioned that the threads are broken?
No, I only assumed so.
Si P
Member #: 912
North Yorkshire
No threads broken, Just off down the nut and bolt shop for the correct threaded socket cap bolts.
Properly have to buy a million.
Clutch slave cylinder mounting is a different thread again I think. Well, the bolt out of it did not fit!
Si
