Home > Help Needed / General Tech Chat > Help with cooper tank :(
jamesfawcett
Member #: 218
Bingley, West Yorkshire
hi i got my cooper tank, with the pump. Well i think its the pump, is it like a round thing bolted on the side, but on the inwide if you know what i mean? A large round disk? It has two electrical connections on it and two 8mm pipes coming out?
Also, one pipe has a orange ring round hte end, the other is plain, but i cant tell which is which :( which is the return? How much do these tanks go for usually?
also, will a pipe that i have from the metro that goes from 10mm to 8mm, an old heater one, work with fuel?
thankyou
james
icklebits
Member #: 228
pump should be on top when installed in car!
pipe nearest the seatback (when installed) should be feed to engine and the one nearest boot is return (iirc)
heater pipe as fuel pipe nononono! fuel is under a bit of pressure from this tank so get some proper fuel pipe intended for use with fuel injection
ryan
jamesfawcett
Member #: 218
i just thought. Now, my pipes that go under the car arnt long enough to reach the top of the fuel tank then :(
i had them reaching just to the metro pump on the rear subframe :( im going to need to join some together.
So if its a pump, i wont need the 10mm anyway beause on the tank the outlets are 8mm :) no need for heater pipes :)
icklebits
Member #: 228
the way i have done it is to use 8mm i/d fuel injection rubber pipe, down the tank and out under the car where it meets the 2 copper fuel pipes running the length of the car, these are upswept to stop them catching and the pipes just join onto the copper pipes
ryan
Yeah im using 8mm injection fuel pipe straight through the car, well i will when it comes in the next day or two.
DO you need some sgort bits of 8mm feeb? ive got a bit kicking about at home thats all.
Carl
Member #: 95
liverpool-on-sea
if your still uncertain about pipe connection undo the 10mm nuts and lift the gold part with the pump on out of the tank(if youve not fitted it) and its easy to see which is return and feed.
*smiley*
billydude
Member #: 48
Leicester
the orange ring should be on the outlet
jamesfawcett
Member #: 218
Nice one! thankyou billy, ill take that in mind, just for piece of mine though ill takje minime's advice and remove the pump before i put the tank in.
Iain!!! PLEASE could you bring me two small pieces of 8mm copper pipe? Just enough to extend either hose? thankyou :)
jamesfawcett
Member #: 218
cant work out the electrical prongs, and dont want to get htem wrong way round and suck fuel from the engine! Theyre in a "T" shape, but not labeled in any way :(
billydude
Member #: 48
Leicester
the brass one is live and the steel one is earth
Carl
Member #: 95
liverpool-on-sea
look very closely at the 2 prongs one of them is welded to the pump housing (left i think but check) this is the earth one *smiley*
jamesfawcett
Member #: 218
Bloody hell, ive had to bodge that in big style.
Do they have different strap mount positions???
jamesfawcett
Member #: 218
also, do i use a 15amp fuse like with the metro pump?
Carl
Member #: 95
liverpool-on-sea
mine fitted straight in no probs you might need a new strap to match. im using a 15 amp fuse *smiley*
jamesfawcett
Member #: 218
no its the actuall mount where the strap bolts into , the tank wont even slot into place because of that mount.
