| Home > General Chat > to wrap or not to wrap? | |||||||
250 Posts Member #: 1615 Senior Member Ferndown, Dorset |
7th Nov, 2007 at 06:24:24pm
puttin a 45dcoe on my n/a in nxt couple off weeks, would it be beneficial to wrap the inlet in that heat wrap or leave it? On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind. |
7th Nov, 2007 at 06:34:28pm
Wrapping exhaust manifold is top priority. Stop the heat at the source. On 19th Jan, 2010 wil_h said:
7th Nov, 2007 at 06:34:57pm
Here's mine, and my friend's:
7th Nov, 2007 at 06:42:14pm
it looks like your friends zipties may melt, Edited by Joe C on 7th Nov, 2007. On 28th Aug, 2011 Kean said:
7th Nov, 2007 at 07:24:32pm
cheers chaps, shall get on an get some then! On 1st Mar, 2009 MikeRace said:
7th Nov, 2007 at 08:23:32pm
not sure about this one as it could HOLD heat in! Best 1/4 mile 13.2 seconds @116 mph
7th Nov, 2007 at 09:14:14pm
7th Nov, 2007 at 10:00:25pm
so have you tested it then?? how you know it won't hold the heat in????? Best 1/4 mile 13.2 seconds @116 mph
7th Nov, 2007 at 10:01:59pm
i think the temperature gradient is going the other way mat, "Turbo's make torque, and torque makes fun"
1425 Posts Member #: 690 Post Whore Norfolk |
7th Nov, 2007 at 10:18:21pm
the best option is to ceramic coat the manifold on the outside and the mating flanges, copper coating first then ceramic. On a warm day I would get condensation on the outside of the inlet manifold. I personally don't think wrapping the manifold in a little blanket before tucking it up in bed will help !!
If Carling made Mini engines
8th Nov, 2007 at 08:11:16am
Mat, because there's no heat element inside the carb. The carb is fed with cold air, colder than engine compartment temps. What's heating the air inside the carb? Nothing. On 13th Jul, 2012 Ben H said:
![]() 865 Posts Member #: 951 Post Whore Bromsgrove |
8th Nov, 2007 at 08:43:15am
Put reflective coating on the inlet(chrome plate?) to reflect heat. 'Where does the engine go?' |
8th Nov, 2007 at 12:00:00pm
Well the carb is connected to the headand that get hot, as well as the carb getting hot to, If the air cools it so much why is it that most carbs are still red hot after a hard run? Best 1/4 mile 13.2 seconds @116 mph
8th Nov, 2007 at 12:38:07pm
forced induction is a different kettle of fish mat, is this what your referring to?
8th Nov, 2007 at 12:42:37pm
No I was talking about the NA I had. Yes your right in the winter they can Ice up, but in the summer, mine way always very hot. Edited by Miniwilliams on 8th Nov, 2007. Best 1/4 mile 13.2 seconds @116 mph
8th Nov, 2007 at 01:10:08pm
The inlet is never hot when you're driving. It's when you're stationary that heat rises. The inlet is fed cold air ALL the time when driving.
8th Nov, 2007 at 01:32:38pm
unless the timing is way way out "Turbo's make torque, and torque makes fun"
8th Nov, 2007 at 01:38:06pm
Doesn't matter at all. The carb is still sucking cold air from the outside. The faster/harder you go, the colder the carb.
The one with the zip ties is mine infact. Used along with this:
