Home > Help Needed / General Tech Chat > ENGINE FITMENT BASICS
stevecoolerking
Member #: 155
im fitting my motor tonight and over the wk end has any got any good tips ? i noticed some one mentioned to try and get the bulkheadbox nice and low anything else ? oh and there was summin about the carb heat sheild being in the way do i need to remove this?
Fit the box and away you go. just look at the pics we've done in how to and you'll find it goes in easy. Shield may foul, i take it off for initial fitment of the engine then put it on afterwards. It is tight though with the std steady, auto or adjustable steady does the job better.
stevecoolerking
Member #: 155
so it can be done with standard cos thats all i got !
cheers iian
t3gav
Member #: 229
Gavin@minispares.com
kent
most people also recomend drilling the engine mounts 1/2" further forward to get more clearance, better cooling etc, also i'd get theadjustable engine steady, mine fouls the bulkhead without it!
