Home > Help Needed / General Tech Chat > Engine Spec Advice
dn89mini
Member #: 1506
Cheshire
Guys,
Now that winter is coming and track day season is all but over I am trying to re-focus on my Mini project. I plan to finally get to converting it over to a turbo and would appreciate your thoughts on the spec. The car will be for track days only.
So, I am thinking
1310cc 9:1 compression
Mirage Manifolds
T2 turbo
Decent Intercooler
SC/CR Gearbox and Drops
Custom Plenum and Dump Valve
I have already converted it to jenvey fuel injection and have mappable fuel and ignition.
I am thinking that this set up running at 10-12psi should be good for 130bhp? The car is stripped out so this should give me a decent power to weight ratio (aiming for 200 per tonne)
My friend is trying to convince me to keep it NA and have it run a highly strung 1380/1400 but your cars on here are a great inspiration and I think the turbo is the way to go.
Any input would be appreciated
Thanks
Check out the (slow) progress at.......
http://www.turbominis.co.uk/dn89mini
the compression ratio will be an interesting one
Itll be fine for what you propose, but possibly limit you on boost in the long run, however it will make a lovely road mannered engine
Seems a good sensible build and will easily get the power you want
What are your plans for the head and cam?
go for 1380cc use accralite pistons18cc dish and a kent 266 cam or a shade wilder avonbar phase2
you will then be pushing near the 200bhp mark *surprised* *wink**wink*
I wonder when some one will try the Kent 274SP cam on a turbo motor?
Watch this space
dn89mini
Member #: 1506
Cheshire
I have a decent head already (might need opeining a little for compression) and no thoughts on the cam yet. The car is going to be track based now so doesnt have to be too clean for the road.
Would 200bhp be too much? I know it sounds daft but would the car be able to put that power down?
Yeah I remember you mentioned that one to me previously Sprocket. Might be worth another look into I think.
The shopping spree starts next month, bolleaux to christmas presents for everyone else.
then it has to be a phase 2 cam all the way!!!
If it's a track day car then as Nic says you can afford to drop the CR to allow more boost. this will affect drivebility at low speed, but that's not a problem in your case.
200bhp might make the car a bit wild, but 150 is perfectly useable in a well setup car.
it seems 150bhp is a pretty good power to go with, i will be running quite a high cr, around the high 8 mark maybe 9s. In my lightweight motor it should be pretty interesting.
dn89mini
Member #: 1506
Cheshire
Thanks for all the input guys!
