| Home > Help Needed / General Tech Chat > Bearings for steering column | |||||||
96 Posts Member #: 251 Advanced Member Nottingham UK |
18th Nov, 2007 at 02:07:38pm
Hi
18th Nov, 2007 at 06:44:27pm
I used a Maestro/Montego shaft, but I used the whole column, so the standard bearings were retained. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Nov, 2007 at 07:29:26pm
Thanks will, I was thinking about doing something like cossie ricks with the two rose joints and UJ's |
18th Nov, 2007 at 08:30:24pm
I use the bearing from the idler gear on an A+ gearbox, the id fits thes of the std mini steering column Team www.sheepspeed.com Racing
18th Nov, 2007 at 10:24:20pm
rose joint will be fine but unsure on size as am not using a standard colom |
19th Nov, 2007 at 11:39:48am
Thanks guys for your help, Jim one more question how high is your front cross bar from the top of your boxes to bottom of the tube? I ask as I will be using the curley dash but havn't bought it yet so not sure where to put the cross bar. I know you are using the curley dash.
