Home > Help Needed / General Tech Chat > sorry iain still confused!
t3gav
Member #: 229
Gavin@minispares.com
kent
hello again sorry but i'm still confused is the anti run on valve also known as the float chamber venting valve, as on my car i seem to have this but it has another pipe coming offit and two wires neither of which seem to go anywhere!
also do i need thepressure reducing valve and solenoid? sorry about all the questions!
anti run on valve/vent valve. One and the same *smiley* just block it off.
if you arent using the ecu then the pressure reducing valve (if i think it what you mean) is redundant. Its basically an electronic bleed valve controlled by the ecu.
*smiley*
t3gav
Member #: 229
kent
thanks again mate!
No worries *smiley*
What the site is here for.
