Home > Help Needed / General Tech Chat > Facet Red Top Fuel Pumps
Anton
Member #: 764
Staffordshire
I have a Facet Red Top Fuel Pump on my 1380... but it seems to intermittently failing. When cruising 3.5k+ after a while i feel the car seem to lose a little power. If I reach back and feel the fuel pump its vibrating more than usual. I give it a quick wiggle it goes back to normal and the engine picks up again.
I believe these pumps are re-buildable.. Anyideas where is start looking for a kit? Ive had a quick Google and a cant find much info.
it sounds like its cavitating, ie low fuel level,
Kean
Member #: 341
aka T2clubby
South Staffs
Do you think maybe its not low enough Ant??
You dont need a rebuild kit. Unscrew the end cap, pull the piston out and clean it.
Paul
Mirage
Member #: 119
i think Fastcarl may have this. Do you have a fuel filter before your pump ? Are there any obvious points that the line could becone air locked before the pump ?
graemec
Member #: 1424
Carnforth, Lancs
Must be an interupter type if you think its rebuildable - large cylinder shape. If so it shouldn't air lock as these can suck quite well, however it may draw air if fuel level is low as Carl says.
But if fuel level is fine then take the bottom off, clean filter and internals and try it again.
Anton
Member #: 764
Staffordshire
it deffo not low fuel level as it does it with the tank full...
Could it have anything to do with tank breathers?
shane
Member #: 1246
Lowestoft, Suffolk.
yes if they are blocked as the fuel cell will be in a vacume with the pump drawing fuel out, does it happen with the filler cap loose?
Shane.
