Home > General Chat > Split Manifold
chris4500uk
Member #: 2097
Middlesbrough
Hey All,
I've just come from a 5 mile journey only to think that the mini is sounding a bit tractor like.
After the petrol station it was kinda obvious what had gone, since it was raspy and had no boost !
blooming manifold from the head to the turbo has split, doh!
Since its a custom designed exhaust manifold im a bit stumped on what to do. It kinda means i cant use my mini :(
evolotion
Member #: 83
Glasgow, Scotland
get it welded up!?
Denis O'Brien.
chris4500uk
Member #: 2097
Middlesbrough
seems like my only option
Leonard
Member #: 806
Cirencester, Gloucestershire
is it stainless steel? just get someone to tig weld it up if so. where are you based?
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Add your location to you 'my control panel'
Someone local maybe able to help. :)
On 19th Jan, 2010 wil_h said:
Ah! the splitting of the custom turbo manifold, not an uncommon problem.
I'd get used to welding, if it's split once it'll split again.
Mirage
Member #: 119
Can you post a picture ?
chris4500uk
Member #: 2097
Middlesbrough
I'll try and get a picture up
I'm located in Middlesbrough
