| Home > Help Needed / General Tech Chat > Verto clutch requirements | |||||||
![]() 214 Posts Member #: 1574 Senior Member Malta |
3rd Dec, 2007 at 09:18:15am
Right I'm down to the last few mods. I've been reading some posts like this one (http://www.turbominis.co.uk/forums//index.php?p=vt&tid=153697) and just want some clarity. My engine is a low mileage genuine 1275 MG turbo. Its been modified with a Benross head, flowed manifolds and running a 266 cam, SC gearset etc. I intend to go up to 12 to 14 psi. Will my verto clutch and flywheel be OK? If not what do I need to replace and what with? Opinions anyone?
3rd Dec, 2007 at 10:03:41am
the vertro will not cut the mustard john
3rd Dec, 2007 at 10:34:13am
As steve says. Verto will not do the business at those boost levels.
Edited by Tom Fenton on 3rd Dec, 2007.
3rd Dec, 2007 at 11:53:47am
Damn - looks like more shelling out. My bank manager thought I was nearly there too!! Will the flywheel housing and WOK still be OK guys?
3rd Dec, 2007 at 12:19:09pm
Flywheel housing and wok fine. You may need to change the starter motor though to suit the flywheel ring gear, usually the early flywheels have the inertia type starter ring gear.
3rd Dec, 2007 at 12:20:44pm
I think that you can choose the ring gear. Mine is an early type Ultralight flywheel with a late starter motor (piggyback type)
Edited by theoneeyedlizard on 3rd Dec, 2007. In the 13's at last!.. Just |
3rd Dec, 2007 at 12:28:17pm
Thanks for the help guys.
3rd Dec, 2007 at 01:16:14pm
If you are of the 'tinkering' type, you might like to try a double diaphram. Whilst not the most easy solution, it will certainly work and be cheaper than all the other bits.
3rd Dec, 2007 at 03:51:41pm
I think this was the post (I'd already read it) http://www.turbominis.co.uk/forums//index.php?p=vt&tid=10207 and it seems a bit too much 'tinkering' for me to risk with a brand new SC box I'm afraid. Thanks anyway Dave.
