Home > Help Needed / General Tech Chat > 4 pots - non vented to vented??
bertieboo
Member #: 1613
N. Ireland
hi,
i have been offered a set of non vented metro 4 pot calipers, I was after the vented type but the fella says you just need a spacer and longer bolts then you can run vented discs, is this right?
Edited by bertieboo on 3rd Dec, 2007.
Yes, it's correct, but why not use it as it is? I am. Vented discs are overkill.
V's right, the vented discs just add weight. Use the 4pots with the solid discs, that's what i did and they're fine.
bertieboo
Member #: 1613
N. Ireland
then is there much advantage over the standard 2 pots on a mini? because they have 2 big pistons rather than 4 smaller ones like on the metro?
