Home > Ebay items For Sale > Mini Turbo kit for sale
8portpower
Member #: 1713
Southam, Warwickshire
For sale - Ebay auction
I am selling a complete kit of parts, to add a Turbocharging system to your Mini. ( wiring and water hoses not included, the odd bolt / stud ,may be needed)
This list of parts included is:
Complete Turbo with inlet and exhaust elbow.
HIF Turbo carb. with plenum, inlet manifold, and heat shield.
Turbo electronic distributor, with cap and leads, with original Metro Turbo control unit.
Exhaust manifold to bolt to a cylinder head.
Original Lucas Turbo boost control unit - this will limit the bost - ideal if you are new to the Turbo route and have a helical gearbox ( rather than the stronger straight cut type which is quite expensive)
Metro Turbo oil cooler
Front mounted Turbo radiator with the two water connections to the one side ( easy pipe routing when attaching coolant pipes to the theremostat housing)
Turbo fuel pump
Pressure regulator
Thermostat housing with sandwich plate
Original Metro water header tank
I also have the original Metro Turbo cylinder head. The valves are a little rusty, and i would recommend this is reconditioned, as it has not been used for 8 years. I will include this for free.
To my knowledge, all of the above parts were in good working order when they were removed.
If I were now refitting the above kit of parts, I would have the cylinder head modified and gas flowed, recondition the Turbo, wire up the distributor, and purchase connecting coolant pipes. You should have everything you need then to Turbo charge your Mini.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...:MESE:IT&ih=007
Trying to clear some room in the garage of projects not completed !
Thanks
Please add your location as per site rules.
8portpower
Member #: 1713
Location is Southam, Warwickshire.
