Home > Beginners Tech > buy guide metro turbo
jaapio1984
Member #: 2120
Marum, The Netherlands
Guys (or girls)
I saw a metro turbo engine for sale. But before i buy it, are there some points wich i can check, to make sure it's ok...
a sort of buy guide..
The number is: 12HC16AA 100964
Jaapio
well it all looks there ....... these engines most of them are 20 years old now
and rest assured they will be worn out
they will need a full rebuild if your going to up the power
From the pic, it looks like an early one as well. The area around the thermostat is machined flat. Can anyone confirm?
Don't recall ever seeing the 'flat top' 12G940 on any turbo motor?
I could be wrong of course!
12HC is also not listed as being a 'turbo' engine either???
How much is he asking for it? If the engine isn't a turbo I'd still be tempted to buy it, then rebuild it. Simply because all the bits are in one place and it saves the hassle of tracking them down individually.
Edited by minimole23 on 3rd Dec, 2007.
I think that 12HC is an early NA Metro engine.
look...
http://www.mgcars.org.uk/news/news498.html
did any metro or A+'s feature a flat top head? I thought these were the older versions of the 940?
Turbo Tel
Member #: 588
Delaware, USA
The answer is "maybe" !!
The Metro engine I bought had a flat top 12G940 with it and I wondered about that as well. It has triple groove valves which seem to be metro sized and the heater takeoff was plugged which makes me think that it was indeed for a metro. The rest of the engine was deffo a Metro but it had a CR of around 10:1 so keep that in mind...as it looks like someone has bolted a turbo on a standard engine. As has been said thats no problem as long as the price is right and you are prepared to rebuild it properly if it turns out to be the case.
my engine number is 12H907AA
jaapio1984
Member #: 2120
wow thx for the fast answers!!
- http://www.google.nl/search?hl=nl&q=12HC16AA&meta=
- he's asking €800 for it
Jaapio
jaapio1984
Member #: 2120
update:
the seller will check weither the number is correct. He does not know from wich year it it :(
I hope it isn't a std metro engine, wich is turbocharged without modifing the rest of the engine...
Jaapio
I guess you could try to pursuade him to rip the head off to check the piston number. unlikey, but if you don't ask you don't get.
jaapio1984
Member #: 2120
just recieved and answer.. the engine was running properly when it came out the old metro..
What numbers must be on the pistons, to make sure they are correct??
