Home > Help Needed / General Tech Chat > can anyone identify this?
lil stu
Member #: 837
rugby
Alright guys can any tell me what this is out of?
its got 11 head studs,
and the code is 12h 298f 38457
its the distributer clamp and the extra castings on the back that threw me.
can it be used in a mini?
steveobennet
Member #: 1657
wirral
looks like an early a (not a+) block. i'd wait for someone to confirm this.
On 15th of Apr, 2007 at 09:08pm Vegard said:
What the fuck is that on the rear of the car? One of the most stupid things I've ever seen. Rest looks nice.
10.5 psi no idea how many banannas
yes it is
lil stu
Member #: 837
rugby
cheers guys.
its not as useful as i had hoped.
danboy
Member #: 1381
Looks just like my 1275 GT block
Dave
danboy
Member #: 1381
On 8th of Dec, 2007 at 06:20pm lil stu said:
cheers guys.
Why not? If it has not got the hole above the centre main it should be as good as any other block
Dave
lil stu
Member #: 837
rugby
you mean an oil hole?
danboy
Member #: 1381
No, In the block, directly above the main bearing housing. The hole is about 3cm x 2.5cm in the web between the base of cylinders 2&3 and the top of the main bearing housing.
If you don't want the block i will buy it from you.
Regards
Dave
lil stu
Member #: 837
rugby
i will have a look and a think cheers mate
Worthless mate. However, if you drive it up to Minispares North, I'll pay the petrol *wink*
lil stu
Member #: 837
rugby
might use it, i reckon, am i gonna struggle to find a 11 stud head?
could a normal one be modded?
yep,
use a head gasket to mark the hole and whack a pillar drill through it.
even if it does have the hole above the centre main bearing it might well e ok in a turbo motor as it will not be spinning to crazy rpm.
I'd just run a dremmel round the hole to get rid of the pointy bits and use it.
That deffinatley a 1275 gt block, i have 2 of those in my collection of blocks!
Well, it could be an Allegro /1300/ 1300GT block as well. Not easy to tell whether it's a 1275GT one.
Even if it's got 11 holes, you don't need that on you head. The gasket will seal if there's a hole to the waterpump. When this is said, it's easy enough to drill the two holes.
lil stu
Member #: 837
rugby
cheers for the help guys i will mod a head. and 1380 it for future use.
Bore it to 1293. The only sensible thing. If not I'll give you two A+ block, and you give me this :)
lil stu
Member #: 837
rugby
the one im running is a 1330, was thinking of the next upgrade.
arnt you a bit far away for exchanging blocks?
Edited by lil stu on 11th Dec, 2007.
