| Home > Help Needed / General Tech Chat > webber carb | |||||||
45 Posts Member #: 2014 Member Carlisle |
10th Dec, 2007 at 11:42:31pm
I am toying with the idea of using a webber on my turbo project, anyone got an idea of if i can get hold of a plenum for these? or will i have to go the custom route? |
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
10th Dec, 2007 at 11:46:49pm
If i remember right janspeed use to do these as in the yellow bible. But youll probably be better off getting one made. Edited by Jordan on 10th Dec, 2007. Back once again like a renegade master |
11th Dec, 2007 at 07:42:38am
No Janspeed used a Dellorto. |
![]() 902 Posts Member #: 111 Post Whore Loughborough |
11th Dec, 2007 at 09:19:24am
don't you have big problems trying to run possitive pressure thought a Webber/Dellorto? I know it can be done with a pull thought turbo. |
11th Dec, 2007 at 09:27:46am
Ask Jukka. The only one done back to back tests on these.
![]() 143 Posts Member #: 1506 Advanced Member Cheshire |
11th Dec, 2007 at 09:36:36am
If you use weber or dellorto in a turbo application you have to update the seals. They are available as the Lotus Esprit turbo used them, but it would be an expensive task. Check out the (slow) progress at.......
11th Dec, 2007 at 10:02:08am
Only reason i would use a Weber is for Suck Through to get the throatyness, otherwise i would leave well alone, as the lads say theyre meant to be a cowbag to setup. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Dec, 2007 at 12:42:17pm
youll also need the laterplastic floats as the boost/fuel pressure might crush the wafer thin brass ones "Turbo's make torque, and torque makes fun"
11th Dec, 2007 at 05:32:10pm
after reading your replies and having a scout about on the link from vegard.
11th Dec, 2007 at 05:35:07pm
why bother mate?
11th Dec, 2007 at 05:37:48pm
1) Its a WEBER carb i.e. only ONE "B"
784 Posts Member #: 912 Post Whore North Yorkshire |
12th Dec, 2007 at 01:23:59pm
Would it not be possible to use 2 SU's..? I drill holes in everything..! |
12th Dec, 2007 at 01:28:45pm
Anything is possible given time effort and money, but has to be weighed up for benefit gained versus time effort and money expended.......
12th Dec, 2007 at 01:37:27pm
why? "Turbo's make torque, and torque makes fun"
12th Dec, 2007 at 01:43:54pm
On 12th of Dec, 2007 at 01:28pm Tom Fenton said:
Anything is possible given time effort and money, but has to be weighed up for benefit gained versus time effort and money expended....... Money expended? Money spent? On 13th Jul, 2012 Ben H said:
13th Dec, 2007 at 11:29:53am
I dont think anyone has tried twin su turbo? Not as far as i know anyway. You can calculate til numbers are coming out of your arse, but the proof is in the pudding. If you can do it try it! It may give decent results?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
13th Dec, 2007 at 05:31:50pm
only way is to have a go, so i may aswell try, if it is successful or not ill let people know. |
13th Dec, 2007 at 08:01:16pm
I did see a weber manifold (maybe in Vizards little yellow book) that you could also fit twin SUs on. They were nice and close and it would be easy to fab a plenum for. On 7th Nov, 2008 Nic said:
