| Home > General Chat > Mini spares comp layshaft | |||||||
![]() 243 Posts Member #: 89 Senior Member Sydney Australia |
17th Dec, 2007 at 03:03:19am
Hi all,
179hp on 12psi 1293cc of pure A series
17th Dec, 2007 at 03:13:32am
they are not as good as the OEM parts
17th Dec, 2007 at 08:50:22am
Have a read of this:
17th Dec, 2007 at 12:22:39pm
Has anyone tried and tested the so called high grade race quality item from dare i say it....Minispeed?
-MINI CLUBMAN 1380 TURBO- |
17th Dec, 2007 at 12:35:51pm
yes i still had wear with the MiniSpares comp layshaft. Edited by Miniwilliams on 17th Dec, 2007. Best 1/4 mile 13.2 seconds @116 mph
17th Dec, 2007 at 04:18:45pm
I understand swifty have had some made that are the best you can get (they had to do this - for their own gearkits) On 17th Nov, 2014 Tom Fenton said:
17th Dec, 2007 at 04:22:54pm
best one to get in my opion is a standard original out of a 998 box, seem to last alot longer than any style of new one i have used or fitted, plus the use of millers cvt seems to make a difference to. always looking for them bigger bunches of bannanas |
17th Dec, 2007 at 06:27:53pm
I got a couple from Australia. Comp-ones. Suposedly very good, but I haven't taken one out yet to see. On 13th Jul, 2012 Ben H said:
18th Dec, 2007 at 05:26:13am
thanks guys,
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
18th Dec, 2007 at 07:12:14pm
at my old college we had the equipment to do propper hardness tests, called the vickers test or somthing along those lines a diamond tip is pressed into the metal and then recorded onto the computor, obviously the more pressure requires to push into the material the harder it is
Edited by mini93 on 18th Dec, 2007. David. |
18th Dec, 2007 at 08:53:48pm
rockwell? "Turbo's make torque, and torque makes fun"
18th Dec, 2007 at 09:15:55pm
i dont know what rockwell test it, just by looking at google images the test equipment looks similar so could i guess be different name or just a different proceadure for the same outcome David. |
18th Dec, 2007 at 09:26:25pm
if anyone has old ones going spare they could send it to me, my friends still there (at college) and recons he could get it hardness tested David. |
61 Posts Member #: 1885 Advanced Member somewhere |
18th Dec, 2007 at 09:29:08pm
im still at the college mini93 and i went to. if someone can supply me with one of each i can test them when i go back in january. we use the test mini93 described above. surely this is the only way to know for certain which is stronger?
18th Dec, 2007 at 09:53:31pm
I have a brand spanking new standard Minispares layshaft that is bolloxed and unused, it wasnt machined right. Its one that is supplied in their rebuild kits, cant remember the part number off the top of my head.
18th Dec, 2007 at 10:19:35pm
as dans at the college, would be better to send to him i guess, but i believe you might already have my address (if you still have it anyway)
David. |
18th Dec, 2007 at 10:23:18pm
Does anyone know how they are hardened?
18th Dec, 2007 at 10:59:16pm
they look induction hardened at the baering journals On 26th Oct, 2004 TurboDave16v said:
18th Dec, 2007 at 11:05:05pm
Bet they didn't used to be
19th Dec, 2007 at 01:30:12pm
pm on its way to sprocket |
22nd Apr, 2010 at 02:58:24pm
So what were the results of this? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
22nd Apr, 2010 at 08:17:32pm
On 22nd Apr, 2010 matty said:
So what were the results of this? They are sold out!
