Home > Help Needed / General Tech Chat > K1100 CAM BOLTS
turboestate
Member #: 362
durham area
Hi could anyone point me in the right dirrection as to where i can ge some 65mm long m10 x 1 bolts to hold my pullys onto the cams, as ive exhausted all my avenues with no luck no one goes that fine a pitch, any help is great.
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
pickmeup
Member #: 1200
have you tried BMW or motoworks the bike breakers, surely they should have some??
mikemph
Member #: 449
Oxford
Toolmaster cowley oxford is where i got mine from think they where about 65p each. 8.8 nickle plated bolts. Perfect for the job
Edited by mikemph on 19th Dec, 2007.
Have you tried Namrick?
Got mine from Namrick, arrived next day!
turboestate
Member #: 362
durham area
Nice one guys just oredered from namrick think ill be saving that site
______
/___|_____
_ (@)___(@)
Care to share some picy's of this project..lol *wink*
is 8.8 a high enough grade for these?
Standard were 12.9 weren't they? And that was a little chainwheel, not a big pulley?
I could be wrong. Has happened may times before LOL!
turboestate
Member #: 362
durham area
Well i also thought this but the adapters fit inside the cam and the bolt spec for 8.8 is 50-55 tons/square inch, i was also recomended namrick by John K last night and 8.8 is the highest grade they sel,
yes will be posting pics shortly
______
/___|_____
_ (@)___(@)
What grade are you using Jim?
I'm sure I'm using 12.9 which Jon Kimmins kindly gave to me. They are a bit on the long side though.
wqell cut the fuckers down daft lad,
Well cut the fuckers down daft lad,
he he, or just get the right length,
I bought mine from namrick and Im sure mine are at least 10.8, Perhaps not?
Edited by Sprocket on 21st Dec, 2007.
