Home > Wanted > CLutch plate support?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
im using a shorter arm style clutch, but the bracket it is on flexes! Ive never noticed it before, ive used the same bracket on all my previous setups, but its quite bad! Never seen it, cna you get a rod or something to the bracket from the flywheel houseing to support it?
i need one!
It has to bolts at the top then a bolt with a tube at the bottom, tube going between the plate and clutch housing.
It goes in where the pre verto throw out stops goes.
Just find out the bolt size then get a small bit of tube to use as a spacer. *smiley*
