Home > For Sale > ***HIGH SPEC TURBO ENGINE PARTS - BARGAIN!!!***
fc6aw
Member #: 742
north london
MED 1293: 3,000 MILES PLUS WALLY = CRACKED BLOCK FOR SALE!
COMPLETE WITH THE FOLLOWING:
- 28cc DISHED LOW COMPRESSION FORGED PISTONS = STILL IN GOOD WORKING ORDER.
- BALANCED CON RODS + NITERIDE TURBO CRANK + MINI SPARES TURBO CAM.
- MINISPORT FAST ROAD/RALLY CLUTCH, 500 MILES OLD.
- TIMKIN ROLLER BEARING DROP GEARS - STRAIGHT CUT!!!!!!!!
- JACK KNIGHT STRAIGHT CUT GEAR BOX!!!!! - WITH CENTRAL OIL PICK UP PIPE, (NEW WHEN ENGINE WAS BUILT) WITH MINISPORT X PIN DIFF - 500 MILES OLD, ATTACHED.
- 3.1 FINAL DRIVE
PRICE FOR ALL OF THE ABOVE (AS A COMPLETE BROKEN ENGINE BLOCK - BUILT TOGETHER) - £650!!!!
OR....
PLUS THESE ANCILLERIES:
- METRO TURBO CARB, T3 TURBO, BRAIDED OIL FEED PIPE, INLET/EXHAUST MANIFOLDS, PLENUM CHAMBER COMPLETE WITH BAILEY DUMP VALVE, 8 ROW COOPER S OIL COOLER. ALSO, 13 ROW OIL COOLER AND SUPERCOOL 2 CORE RAD (SLIGHT FAN DAMAGE BUT NO LEAKS!!) Also toyota supra intercooler & silicone pipeing, with fan. full maniflow turbo downpipe an exhaust system.
- STAGE 5 CYLINDER HEAD = CRACKED, BUT HAVE A RECONDITIONED 1275 HEAD, ALSO FOR SALE.
£750 FOR ALL OF THE ABOVE - THAT'S EVERYTHING YOU'VE JUST READ!!!
WOULD RATHER KEEP ENGINE COMPLETE BUT WOULD CONSIDER BREAKING THE BLOCK UP, ANCILLERIES ETC.
CONTACT VIA THIS WEBSITE OR
PHONE CHARLES ON 07846-452-185 (BASED IN NORTH LONDON)
*wink*
Edited by fc6aw on 27th Dec, 2007.
MarkGTT
Member #: 1194
Shropshire.
Intrested in the gearbox if your willing to split, PM me a price.
cheers, Mark.
MiniKid..
Member #: 1744
Kent & London
PM sent
Advantage
Member #: 1450
Near Paris - France
If I recall correctly, block and head are scrap, all other parts are usable ?
I definitely would have been interested by the whole lot but have to take all these back to France ...
I will check on transport price and PM back to you.
Régis
Rusty by nature
are you sure the pistons have 28cc dish? sounds a lot to me
slater
Member #: 1291
Suffolk / Birmingham
you got pm mate
MarkGTT
Member #: 1194
Shropshire.
any news on this?? im still interested in the box. Cheers
fc6aw
Member #: 742
north london
yeah preety sure its 28cc dish, was set up for high boost, think the compression ratio was in the 7s, still drove ok on low boost though, as for the box, a couple people interested in that an couple other bits so going to hold fire on selling jus the box on its own at the mo. cheers
dave_spr88
Member #: 2014
Carlisle
can i just ask how exactly did you crack the head and block?
what boost were you running before it blew?
Could be interested in the lot just need rough idea what you were running
Adam_R
Member #: 1938
near Dundee
how much?
including postage?
blockshed
Member #: 2168
Hello
Interested in the drops and the crank .
Is the crank a CAM 6581 ?
Are you sure it is not the cylinder head that was 28cc? I have not personally heard of pistons larger than 18cc.
how much are you looking for for the turbo?
pm'd
pm'd about carb, inlet, and exhaust manifolds.
Interested in 13 row cooler and hoses if available?
On 29th of Dec, 2007 at 08:51pm Snakeii said:
how much are you looking for, for the turbo?
smith1380gt
Member #: 2116
Is the gearbox still available? How much? Thanks,
Brian
MarkGTT
Member #: 1194
Shropshire.
Brian
if it is im having it...
I think you all need to phone the seller on the number in the original post.
Advantage
Member #: 1450
Near Paris - France
Has PMed you but no reply, would you consider selling pistons and valves, PM me a price please.
Rusty by nature
