| Home > Help Needed / General Tech Chat > K100 Head - To Plug or to Tap | |||||||
7th Jan, 2008 at 03:20:00pm
I'm about to start dry decking my block for the K100 head before it goes to the machine shop.
Edited by Paul S on 8th Jan, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
7th Jan, 2008 at 03:28:03pm
I don't like the idea of having the not total contact of a thread there so i would plug,
8th Jan, 2008 at 08:43:08am
I'm not concerned with the thread sealing. After all, taper thread plugs are used to seal high pressure water, oil and steam systems.
8th Jan, 2008 at 09:40:17am
I assume the problem area you are refering to are for the holes in the back of the block which use to be for the water gallary. I drilled and tapped these out. The problem here is the deck is so thin, and we can't make sure the plug goes to the bottom of the hole as it is in the water jacket so would need to be about 200mm long each.
8th Jan, 2008 at 04:58:16pm
Thanks, Jimster.
8th Jan, 2008 at 06:23:37pm
this is prob a really stupid q , but why does one need to block the pushrod holes ? doesnt the gasket do that ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
8th Jan, 2008 at 06:28:36pm
Good point.
8th Jan, 2008 at 06:48:21pm
ah i see .thank you paul . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
8th Jan, 2008 at 08:42:49pm
Drill and tap, i used a loctite 648 then to seal and lock them in. Its good up to 175 degrees and will stick most things. I hope mine will stay together its serious enough stuff. |
8th Jan, 2008 at 08:54:24pm
Ahhh,
8th Jan, 2008 at 09:38:35pm
The void it leaves is minimal, i used cast iron bar to make sure that the thermal expansion rates were constant. |
31st Jan, 2008 at 05:30:48pm
I decided to tap the head stud and waterway holes and ream and plug the pushrod holes.
31st Jan, 2008 at 05:50:15pm
I can see where you're coming from re the maching - i certainly wouldn't be fussed as regards the different expansion rates though.
31st Jan, 2008 at 06:42:00pm
Yes, I'll be using a milling machine to drill the new stud holes.
