Home > For Sale > Clearout - pre ebay, big list :)
hi guys and girls, think its time to get rid of some stuff so here goes *smiley*
2) yoko's a539 pair brand new never mounted+ still stickered i think i think they was £48 each, -�70 for pair pickup only
3) non turbo hs4 carb 1 1/4 inch std from 998 used - £30 posted
4) non turbo hs4 carb1 1/2 inch v.g.c - £30 posted
5) non turbo minispares water heated/cooled manifold - £20 posted
6) cone filter k.n from stage 1 kit - £10 posted
7)small bore lcb less y peice free to pickup? ( has been welded at some point i think)
click for pic
click for pic
8.)5" tacko with shift light, max rpm recall, inc instruction goes to 11k so good for bike engine? SOLD
9)2 10" subs, 'VRX' 600watt pmpo 425 rms very bassy when in good box £20 pair pickup only
click for pic
click for pic
Edited by Brett on 14th Jan, 2008.
10) dizzy shaft off of cam-thing £5 + post
click for pic
11) dizzy 998cc, 59D fully working £30 posted
click for pic
12) timing chain plate + cover without breather £20 posted
click for pic
13) pre-engaged starter, very little shaft play wasnt on mini long before engine swap ( and change to inertia starter) working when removed £40+ postaga
click for pic
15)body clips (think you can see witch type, £5 posted
16)plastic 11 blade fan g.c £7.50 posted
click for pic
17)crank pully (not got damper) + water pump pully £10each plus postage/ £20 pair posted
click for pic
1.8)turbo clutch plate, removed after about 500 mile £�offers £15 posted?
next lot
19)gaskets £12.50posted the large one is the extra thick rubberised type for between transfer case and box/block
the little bag has 5 or6 various gaskes + box selector shaft seal and (i think its a)new sump plug copper washer(sell as whole)
20)radiator used, no leaks std 998cc, offers? (postage might be about £15)
click for pic
21)oil filter holder £7.50 posted
click for pic
23)heater was all working was removed because of bulkhead box and modded so the pipes come out opposite side to standard (got in way of my big feet) un finnished project £�offers(postage might be about £15)
24)verto slave + bracket working when removed £7.50 posted
click for pic
25)engine + rad mounting bracket £10 posted
Thank you for taking you time to look:)
what size are the yoko's?
I'll deffo have the front barke hoses for a tenner :)
How would you like paying?
Please add your location to your profile, this is a site rule. Failure to do so will mean your post gets deleted. Thank you.
yokos are 175/50/13 iirc ( yeah prety sure they are)
sprocket you will have pm in about 5 mins lol
EDIT: lol sorry tom its added now:)
all items listed on the mini forum aswell*smiley* cheers
Edited by Brett on 7th Jan, 2008.
what instalation does the tacho require i am quite interested in this can you use it with the megajolt system or a normal dizzy/coil?
philc
Member #: 1346
bromsgrove
I also have one of these and would like some guidance on fitting
philc
Member #: 1346
bromsgrove
interested in the body clips, will these work for the bonnet??
the wiring is pretty straight forward, i got a pick i can just make it out lol,
then there is the back light witch is wired in to the headlights and the shift light wires just plug togeather
the back light is blue (the numbers) and the auto gauge box lights red, looks realy nice in the dark,
does that intercooler fit behind the grill with no modsor few mods i want a standard looking fron end and what are the dimensions?? if so i would be very interested, and im going to give the tacho a miss as i dont really need it at the moment
Edited by Paul R on 8th Jan, 2008.
they could work on the bonnet, asuming its a normal lifting bonnet with the hinges but the way they hold they will either have to be upside down or be in the way of the grill.
they are leftover from what i used to hold the flipfront on to the a-panel
ill take the I/C please let me know on postage costs
i am sorry i cannot give deffinate answer, i have f/g flipfront but i remember test fitting it infont of the rocker cover
dimentions
core = 29.5 x 18 x 8.5 cm (wide, tall, deep)
overall 45.5 x 18 x 11(includind in/out pipes) cm
yes please :) can you let me know postage costs ill pm you my adress
BUMP all updated:)
any more takers? before they go on ebay? open to sensible offers :)
