| Home > Help Needed / General Tech Chat > Does anyone have an empty A+ gearbox case.......... | |||||||
8th Jan, 2008 at 09:54:23pm
.........and scales.
I seriously doubt it! |
8th Jan, 2008 at 10:15:27pm
I may be able to do this over the weekend do you just want weight of the casing on its own or diff casing and output flanges bolts etc? |
1425 Posts Member #: 690 Post Whore Norfolk |
8th Jan, 2008 at 10:20:27pm
I do have a bare case - will weigh it for you Paul
If Carling made Mini engines
![]() 568 Posts Member #: 1200 Post Whore Bristol |
8th Jan, 2008 at 11:08:00pm
ive got a bare case, dis you have the diff housing bolted on as that would add a few grams?
9th Jan, 2008 at 06:50:32am
Case and diff case, no side plates or anything else.
9th Jan, 2008 at 05:40:41pm
My DAM 2886 case, with diff housing and associated studs/nuts, withOUT side plates, withOUT speedo end casting (but with associated studs, and all other studs installed waiting), and unfortunately WITH selector shaft/interlock, bell cranks, selector rods/forks and reverse gear/shaft (ie, all the steel bits you leave in if they were working OK) is 10kg on my bathroom scales.
9th Jan, 2008 at 08:11:45pm
Mine is pretty much as yours but without reverse and its abou 8 1/4 at the mo after around 45 hours of fettling.
10th Jan, 2008 at 04:44:43pm
Was searching for some other gearbox parts this afternoon and came across the above mentioned steel bits from a box I had scrapped a while ago (cracked casing). So, out of idle curiosity, off to the kitchen scales...
10th Jan, 2008 at 05:02:31pm
On 9th Jan, 2008 paul wiginton said:
45 hours of fettling Try the pub Paul, its not so bad...... :)
10th Jan, 2008 at 05:15:56pm
45 hours of fettling Try the pub Paul, its not so bad...... :) Beer bellies are heavy Tom, how will i catch Don with that extra weight? Paul I seriously doubt it! |
10th Jan, 2008 at 05:57:56pm
LOL!
10th Jan, 2008 at 10:04:20pm
ha ha, beer is the best weapon i'm sure! |
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
10th Jan, 2008 at 10:57:22pm
is that tom telling us a secret to the dons sucess? get pissed up? out of interest though paul, where on the casing have you taken material from? On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
10th Jan, 2008 at 11:17:48pm
45 hours of fettling Try the pub Paul, its not so bad...... :) Beer bellies are heavy Tom, how will i catch Don with that extra weight? Paul The extra weigh helps keep the front down and improves traction
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
10th Jan, 2008 at 11:22:14pm
best i get down the pub! On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
11th Jan, 2008 at 05:43:26pm
Anyone else have one to weigh for me?
11th Jan, 2008 at 08:53:24pm
paul is it any use to weigh it if the selector stuff is still in there ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
11th Jan, 2008 at 09:39:54pm
I have a completely bare NOS A-series case if that's any use for a weight comparison? |
11th Jan, 2008 at 10:07:28pm
On 11th Jan, 2008 robert said:
paul is it any use to weigh it if the selector stuff is still in there ? Yes Paul I seriously doubt it! |
11th Jan, 2008 at 10:07:58pm
On 11th Jan, 2008 graemec said:
I have a completely bare NOS A-series case if that's any use for a weight comparison? Yes Paul I seriously doubt it! |
