Home > Help Needed / General Tech Chat > remember my smokey idle ?
b12
Member #: 247
Kent/Surrey Borders
when i sorted my intercooler this weekend
I took the orange pipe of that joins the plenum to the turbo;
the pipe coming up from the turbo had oily residue inside it
the plenum was dry howver ...
Sounds like a seal has gone in the turbo dosnt it ?
Or could the oil I am using be a tad too thin ? I used the oild from the haynes manual ; I think it was 10/40
Wonder if I will be better with 20/50
Anyone any clues ??
steve
TurboLessTosser
b12
Member #: 247
Kent/Surrey Borders
No-One ?
TurboLessTosser
try 20/50 mate, may make a bit of difference. Does sound turbo related though although if its not that bad then i wouldnt worry untill you've got the chance to have it rebuilt.
b12
Member #: 247
Kent/Surrey Borders
funny it did not do it in the metro;
only when I put it in my mini, and gave it some fresh oil
I am just gunna use good old valoline 20/50 racing, i rekon the oil is getting past the bearings ; strange though as its a new turbo on it
S
TurboLessTosser
try dropping the pressure aswell...
(assuming it's not low already!!!)
b12
Member #: 247
Kent/Surrey Borders
"try dropping the pressure aswell... "
TD Not sure what you mean matey !! ( am i being a plonker again :) )
TurboLessTosser
Use a pressure reducer to get constant oil pressure, they're about ?15 from minispares.
You'll see them on the advert, i need one actually at some point.
http://www.minispares.com/web/Item/HPS4/InvDetail.cfm
This kit includes a new oil galery plug with an adjustable knob and a washer which is used as a spring seat in the plug against the relief spring. This makes a playform for the adjuster bolt to adjust the engine oil pressure. Winding the knob in increases pressure, winding it out reduces the pressure.
The standard spring 6K853 is easier to use as its compressed length is shorter and softer for fitment. If you have to much oil pressure, or difficulty in fitting, one coil of the spring ca be cut off at a time. Remember that excessive oil pressure can raise oil temperature and absorbs valuable horsepower.
This kit can only adjust the total amount of oil pressure. That figure should be 50-60 psi at anything over 3000 RPM, any more pressure than that is just heating up the oil and wasting power. You cannot affect the idle speed oil pressure with this kit; whatever pressure you have at idle is governed by internal engine clearances, oil temperature, grade and quality.
Edited by iain on 5th Jul, 2004.
b12
Member #: 247
Kent/Surrey Borders
Wow great information there ... I will look into this ...
Curious though TD seemed to imply the OP should be low
Is the standard Oil pressre 2 high ? I mean I am confused why we would need to change the OP from factory defualt
I am being a plonker here somewhere arnt i !!
S
TurboLessTosser
Its just not very consistant, its only a spring at the end of the day and they all vary. Using this device means you can compensate for varying lengths/strengths of spring
*smiley*
Its ok rodney, your allowed to ask questions *happy*
I've found that if a turbo is a little smoky, it makes a significant difference when the pressure is 60 psi, to if it is 45psi peak... A worthy consideration!
Definately! might cure some problems. Its also worth noting it only stops the peak pressure so it effect it comes up to 45psi and stays there rather than keep climbing as the std one does.
b12
Member #: 247
Kent/Surrey Borders
interesting stuff; I will go get one !!
What oil do yiou guys use then isnt 20/50 too thick for the turbo ?
I know its great for an old engine !
S
TurboLessTosser
Nope 20/50 is spot on.
Turbos like thicker oil as it gets that much hotter in the turbo bearings, dont want it going too thin.
b12
Member #: 247
Kent/Surrey Borders
got my pressure reducer in the post
really sexy bit of kit a big chrome knob !!! and a washer ...
not quite sure what I am supposed to do with the washer mindy you ? Iain any idea????????????????????????????
TurboLessTosser
Nope, never fitted one! I will at some point in the future though, sure it will make sense when you get it!
Soton1310Turbo
Member #: 265
Southampton
The washer is so for the spring to sit on
If not fitted the spring just goes over the threaded adjuster bit which screws in and out.
You might need to cut the spring down as with the washer when it's adjusted all the way out it'll give higher pressure then standard. All it's doing is adjust the point at which the pressure relief valve starts to dumps oil back to the sump. simple but effective
Bit more expensive but you can get the Turbo shaft fitted with 2 oil seals, don't bother with the the staggered gap seals though, they aren't very effective
Edited by Soton1310Turbo on 9th Jul, 2004.
