Home > Help Needed / General Tech Chat > megajolt
welshdan
Member #: 1111
s wales
how much does it cost to get all the parts to run megajolt? how much is it to get it mapped properly for my engine? looking for a ball part figure really. hope you can help, many thanks
MarkGTT
Member #: 1194
Shropshire.
if you make your own trigger wheel and bracket and get the ford bits from a scrappy then about £130 ish (including a new MJLJ ecu)
add another £120 for the trigger wheel kit if you cant make one.
you can try ww.specialist-components.co.uk for this.
cheers, Mark.
welshdan
Member #: 1111
s wales
how about for setup?can this be done at home? are there guides anywhere for making the trigger wheel and bracket? many thanks
dave_spr88
Member #: 2014
Carlisle
setup is done on a laptop at home.
Crank sensor bracket - £14.99
Trigger-wheels £20 upwards
from www.trigger-wheels.com
Thats the company i ordered everything from apart from the edis parts
In total it cost me £230 thereabouts for everything i needed including the coilpack etc... from the local scrappy
Edited by dave_spr88 on 12th Jan, 2008.
Mine was £75 all in but then I made Megajolt unit & sensor bracket myself & got the pulley machined for free.
does it have to be a ford coil pack~? i have heard you can use 106GTI coil packs also?
shane
Member #: 1246
Lowestoft, Suffolk.
I think I got all the parts for mine for under £100 made bracket myself, a friend machiened my pully for beers, all the parts I got from a scrappy for a tenner, and the ecu unit was an ebay find.
Shane
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Use the Ford stuff or you risk burning out the EDIS.
Mapping works out to be anywhere from £50 - £100 an hour. It depends on what you want done ie on the road or rolling road etc etc.
Alex
AlexF
turbochargedstu
Member #: 908
gateshead
alex. i still need mine fixing if your around!
stu
balls to the blower!!!
