| Home > General Chat > Center Main Straps | |||||||
15th Jan, 2008 at 07:56:04pm
I have a concern regading the supply and use of some center main straps.
Edited by Sprocket on 15th Jan, 2008. On 26th Oct, 2004 TurboDave16v said:
15th Jan, 2008 at 08:06:55pm
i use hardened washers , and my straps are 25mmx25mm ms bar.
1425 Posts Member #: 690 Post Whore Norfolk |
15th Jan, 2008 at 08:22:41pm
I don't use washers unless they are known 10 grade or higher - far better to leave the washers off and put a bit of ARP lube under the head of the bolt to reduce friction against surface, something I do with or without washers, over 30% of a bolts applied torque is lost in friction in the thread and on the underside of the head face - I always ensure the bolt hole in the strap is generously chamfered to clear the rad on the underside of the bolt head/shank interface - inch*inch is common for straps sizes
If Carling made Mini engines
15th Jan, 2008 at 08:45:00pm
My thoughts exactly. hmm
15th Jan, 2008 at 09:13:37pm
use the minispares centre main strap supplied with bolts and no washers
15th Jan, 2008 at 09:47:22pm
Ditch the washers, and Steve looks like MS have put there prices up:
15th Jan, 2008 at 10:59:05pm
yes they have rob ...... i will have to have words .......lol
![]() 214 Posts Member #: 1574 Senior Member Malta |
16th Jan, 2008 at 12:20:54pm
My MS centra main strap has just been delivered - its more than up to the job IMHO and no washers.
16th Jan, 2008 at 03:31:04pm
i noticed last year that MS stopped there 4 bolt mains, they also used to do a kit of 3 steel caps inc a 4 bolt mains
16th Jan, 2008 at 03:38:26pm
may be so wolfie, i bet they were not selling many
16th Jan, 2008 at 04:22:04pm
On 16th Jan, 2008 wolfie said:
i noticed last year that MS stopped there 4 bolt mains, they also used to do a kit of 3 steel caps inc a 4 bolt mains stopped because its not a worthwhile mod? They do them again now! Shortage in supply, nothing else. On 13th Jul, 2012 Ben H said:
16th Jan, 2008 at 08:31:45pm
On 15th Jan, 2008 BENROSS said:
use the minispares centre main strap supplied with bolts and no washers around £9 more than up to the job me to. Best 1/4 mile 13.2 seconds @116 mph
16th Jan, 2008 at 09:17:48pm
I heard some miglias don't even bother with the straps? On 17th Nov, 2014 Tom Fenton said:
16th Jan, 2008 at 09:22:30pm
well TBH Dave i only fitted a strap as "its what your meant to do" How can you test such a thing, it might be one of them things that doesn't really do much! Best 1/4 mile 13.2 seconds @116 mph
16th Jan, 2008 at 09:34:35pm
^^^^^ Ditto Above.
16th Jan, 2008 at 09:43:33pm
16th Jan, 2008 at 10:19:14pm
TBH Dave we do a lot of things we don't have to i believe we find this out more and more, It wasn't to long ago when it was "improssible" lol to get 200 bhp now there are lots about. Best 1/4 mile 13.2 seconds @116 mph
16th Jan, 2008 at 10:28:44pm
It is by no means an exact science, so we do things that in theory help produce power or help engine longevity. Whether these things work who knows, but for the low cost surely it is worth trying?
16th Jan, 2008 at 10:38:33pm
For sure If nothing else it's piece of mind, even if it does nothing lol. Best 1/4 mile 13.2 seconds @116 mph
16th Jan, 2008 at 11:54:11pm
It was the Minispares straps I was reffering to. These are some what slimmer than the ones i saw this week.
17th Jan, 2008 at 12:02:36am
ffs, what a tit.
17th Jan, 2008 at 12:04:28am
WITH AN ANGLE GRINDER!!!!!!!!!! FUCKING HELL......
17th Jan, 2008 at 01:06:04am
saw this a few years ago, complete waste of time imo:
17th Jan, 2008 at 02:06:12am
Apparently the bolts spaly out, well thats what it says these prevent On 26th Oct, 2004 TurboDave16v said:
17th Jan, 2008 at 07:58:12am
On 16th Jan, 2008 Sprocket said:
It was the Minispares straps I was reffering to. These are some what slimmer than the ones i saw this week. Although it does help if you use the correct main cap for the block and machine it flat to start with. Or was it one of these http://www.theminiforum.co.uk/forums/index...ndpost&p=174621 LMFAO
Black & Decker comes to mind ![]() What a fucking wanker. Well, it doesn't surprise me that he was the one who said it
