Home > Show Us Yours! > broken leg
or not anymore... i finnaly got the cast off of my leg 2day i managed to get some pictures of the break in on my leg which has now heald up unfortunatly i only have before x-rays not after ones :(.
luckally for me i dont have to go to physio and i can kind of walk arround now :) i just though i would share them with you
paul.
the break was 2" in length but as it was a spiral break it went all arround the bone :(, if you imagen 1cm down from the bottom of my break that is where the ligament which holds your fibula (the one i broke) and the tibia together so i was quite lucky
Edited by Paul R on 16th Jan, 2008.
Leonard
Member #: 806
Cirencester, Gloucestershire
you were very lucky you could double your time off if the ligament is damaged believe me!
blown_imp
Member #: 598
Gaol
I did exactly the same thing, ive a 15cm titanium plate and seven screws in mine now!
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off...
How did you break it then?
poncing around in a pink tutu
Jason G
Member #: 1459
En-suite user
Braintree, Essex
good to see its on the mend bud
On 19th Jan, 2010 wil_h said:
i was doing gymnastics, front handspring over a 4ft box but my hand sliped, so i rotated very badly and landed in a pink tutu as neil said not so good
