Home > Help Needed / General Tech Chat > Long stroke turbo
minmog
Member #: 1119
Hi, i was thinking of building a long stroke turbo engine as I have a block that has bored to 1310, some cooper S pistons and an 84mm stroke crank so total capacity should be circa 1350. My question is what pistons are available that are suitable. I was looking at the Accralites from Avonbar then realised that if I used them they would protrude from the top of the block at TDC. Any help and suggestions appreciated.
Wolfie on the site has a long stroke turbo if im not mistaken and he uses megas maybe good to ask him about them
minmog
Member #: 1119
Thanks, I'll PM him to get some ideas.
try typing "long stroke turbo" into the search engine LOL
You can easily remove two mm from the top of Megas if that's necessary.
minmog
Member #: 1119
A search was tried but didn't answer my question thats why I posted in the help section. Thanks for in the information Vegard, I wonder if it could be done with the accralites I mentioned earlier.
As long as the top ring is a fair way down the piston yes.
its 1355cc not 1350 *wink*
Read the book by Smokey Yunick. You'll be surprised about what he says about top ring position...
Really?
have been meaning to get a copy of that book,
am I wrong then?
He thinks that this all is a bit exaggerated. He doesn't like all the volume above the top ring. All sorts of stuff gets ignited down there *wink*
ordered a copy!
Sounds like a fair point .
I'll have a browse when it turns up.
Theres alot of basic info on this site about my engine, how it went together with the trials and tribulations i had, a search will reveal a basic spec, i am for now going to keep the rest and the finer points of how it went together to myself
May sound harsh and i might get a slating for it but it cost me alot in parts and development and i dont want that info just thrown around the net willy nilly
one thing i will say is its not cheap, you can build a k1100 turbo for less
Edited by wolfie on 24th Jan, 2008.
i have seen if go wolfie and it sure goes!
whats the BHP for the boost ?
