Home > Introduce Yourself > Hello to you all from GTM Driver!
gtmdriver
Member #: 2221
Chester le Street
I've owned actual Minis in the past but for the last 30 years or so I have driven various Kit cars most, but not all based on Mini donors.
In order:-
A Mk III Mini Marcos which I modified for racing.
When I finally sold this car it ended up being bought by the current Marcos company and was used as their demonstrator for 'their' Mk VI GT version.
Then a Mk IV Mini Marcos which I used when I finally took the racer off the road to tune it further.
Next came a Hustler Force 4. This was the last of the Hustler line and had proper opening doors rather than sliding windows. Apparently only 4 were made.
My current car is a GTM Coupe.
I made a completely new GRP chassis to replace the steel one
made my own tubular subframes
and redesigned the suspension to use pushrods and inboard coil overs.
I'm now looking to change from the HIF44 carb to injection using BMW motorcycle throttle bodies
and a Megasquirt ECU.
This forum seems to be the best place to find information on the Megasquirt set up so here I am.
Edited by gtmdriver on 27th Jan, 2008.
welcome, that hustler looks like the taxi in total recall, ace!
codd_coupe
Member #: 1772
Leicestersheershire
Hello John,
Welcome to turbo minis, fancy seeing you here!
A mine of knowledge here.
Tim Rowe
"Is est totus perfectus per fumi quod speculum"
GTM Coupe Turbo
T3Tone
Member #: 252
Sunny suffolk
Hi and welcome, nice work with the chassis and subframes.
-MINI CLUBMAN 1380 TURBO-
Welcome to TM.
Sounds like a good project! :)
Hey :)
