| Home > General Chat > What is this. | |||||||
174 Posts Member #: 781 Advanced Member Norway |
29th Jan, 2008 at 03:47:21pm
![]() 1014 Posts Member #: 238 Post Whore essex |
29th Jan, 2008 at 03:52:31pm
the boot floor? ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
29th Jan, 2008 at 03:54:20pm
Strengthening plate for certain early cars that used rear bump stops I believe.
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
29th Jan, 2008 at 03:54:42pm
do you mean the lip??
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
29th Jan, 2008 at 04:33:44pm
if i dont need it ill cut it off. Saves som weight |
29th Jan, 2008 at 04:38:51pm
On 29th Jan, 2008 Leadfoot said:
if i dont need it ill cut it off. Saves som weight just have a crap before your drive the car, that would save more wieght than cutting that off. |
29th Jan, 2008 at 04:58:00pm
i heard nic drives naked on the strip...is this to save weight or does he think he actually has to strip?
if i dont need it ill cut it off. Saves som weight just have a crap before your drive the car, that would save more wieght than cutting that off. On 2nd Oct, 2009 Vegard said:
29th Jan, 2008 at 05:23:51pm
Im losing waight to get the sob to go faster. iv lost 4 kilos. have about 50 more to go. |
29th Jan, 2008 at 05:37:06pm
I think it ties the boot floor to the arch/damper mount. I recently seam welded around mine whilst repairing the boot floor. Could be wrong though. |
29th Jan, 2008 at 06:00:30pm
If you mean the plate thats welded on, then its for bump stops on hydrolastic cars.
I seriously doubt it! |
29th Jan, 2008 at 07:43:15pm
So what paul means in english is cut the twat off !!!!!!!!!! not needed
On 29th Jan, 2008 paul wiginton said:
If you mean the plate thats welded on, then its for bump stops on hydrolastic cars. Paul |
29th Jan, 2008 at 08:52:27pm
On 29th Jan, 2008 cossierick said:
So what paul means in english is cut the twat off !!!!!!!!!! not needed Rick On 29th Jan, 2008 paul wiginton said: If you mean the plate thats welded on, then its for bump stops on hydrolastic cars. Paul Got it in 1 Rick! Paul I seriously doubt it! |
29th Jan, 2008 at 09:41:14pm
On 29th Jan, 2008 rubicon said:
i heard nic drives naked on the strip...is this to save weight or does he think he actually has to strip? lol aerodynamic efficiency (i get a full wax on the friday morning before) Why the hell did they carry on putting that plate on the later cars? BL and rover could of saved themselves posssibly thousands with the amount they made I thought i must of been a strengthener for the seat belt, balls i could of pulled mine off |
29th Jan, 2008 at 10:24:28pm
On 29th Jan, 2008 Nic said:
balls i could of pulled mine off Nic, you might be desperate to save weight but do not, I repeat do not, pull your balls off, it's wrong & it will hurt a lot. Edited by Rob H on 29th Jan, 2008. Isambard Kingdom Brunel said:
29th Jan, 2008 at 10:36:34pm
hahaha
30th Jan, 2008 at 03:59:28pm
donate to the sperm bank. Then cut them off. |
