Home > Help Needed / General Tech Chat > turbo play
timboc
Member #: 2043
hi, my first post here, been readin for a while now tho, im just gettin to the stage where my turbo lump is ready to go in, i've rebuilt the t3 and am a little worried as i have never seen this turbo running and there is some play on the shaft is this normal?
anyways cheers
Tim 8-)
there will be a little bit, thsi is taken up by the oil
try and measure it with some equipment (feeler gauges will do), i think mine had 0.24mm which was a low tolerence
this is up and down play, not side to side
timboc
Member #: 2043
ok, thanks. so what about side to side, should there be no play here?
tim
none
thats in the x direction, i.e. from left to right if the turbo is in the position that it would be when in the car
timboc
Member #: 2043
ahh ok, thanks nic, think ive got a little bit of play side to side :s not enough to touch the housing or anythinng tho,?
tim
Mirage
Member #: 119
Did you replace the bearings?
timboc
Member #: 2043
yeh, i did. im worried that the old ones may hav spun in the housing which would obviously make it bigger and the play would be on the outer of the bearing not the inner against the spindle, if that makes sence lol.
tim
as above youls see some radial play, but there should be vertualy none if you pull and push the shaft "in & out"
im confused which way can you have play then... my turbo has slight play on it, not if i push on it but if i wiggle my finger on the shaft it moves a bit side to side i geuss. but i have seen brand new turbos do this also so do you mean no play in and out if you were to push on the shaft?
slater
Member #: 1291
Suffolk / Birmingham
Pull and push the shaft along its length and you should not have any. (thrust!)
Wiggle it up and down and you will have some. I rebuilt mine on sunday and it had what i would consider loads of play but i put in new bearings and a differant shaft that was not worn so i can only assume they are supposed to be that sloppy!
as nic said, about .2 odd mm for a t2, which to me looks like loads!
Edited by Joe C on 31st Jan, 2008.
