| Home > Technical Chat > Gap between piston and bore | |||||||
31st Jan, 2008 at 07:13:02pm
On a 1380 (73.5mm) what size gap is it generally between piston and bore?
I seriously doubt it! |
31st Jan, 2008 at 07:14:50pm
edited,.i'll read the OP again,lol.
Edited by fastcarl on 31st Jan, 2008. |
![]() 514 Posts Member #: 2169 Post Whore Malta (Ex. Scotland) |
31st Jan, 2008 at 07:21:08pm
What about offset bores Carl? Warning:Stig in Training
31st Jan, 2008 at 07:37:29pm
It depends on the pistons, forged pistons tend to require great clearances than cast pistons, the manufacturer should be able to tell you the recommended clearances.
31st Jan, 2008 at 07:47:09pm
On 31st Jan, 2008 Rob H said:
It depends on the pistons, forged pistons tend to require great clearances than cast pistons, the manufacturer should be able to tell you the recommended clearances. For stock rover pistons it's about: 20 - 30 thou on the crown 5 - 15 thou on the skirt 0,015" is a lot Rob, where you get that info. carl |
31st Jan, 2008 at 07:56:58pm
is it not 0.05mm to 0.15mm?
Edited by Sprocket on 31st Jan, 2008. On 26th Oct, 2004 TurboDave16v said:
31st Jan, 2008 at 08:02:01pm
There was thread about this a few weeks back and the same error was made. I have mine at 4 thou, but this is an absolute maximum and probably for race only where oil consumption is not a big worry as mileage is small. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
31st Jan, 2008 at 08:03:39pm
Sorry got my self in a muddle:
31st Jan, 2008 at 08:06:21pm
I use 0.06mm which is near 25 thou. Seems to work. FOr instance, I bore the 1293 blocks to 71.12mm whereas MEGA pistons are 71.06mm nominally. On 13th Jul, 2012 Ben H said:
31st Jan, 2008 at 10:05:59pm
On 31st Jan, 2008 Vegard said:
I use 0.06mm which is near 25 thou. Seems to work. FOr instance, I bore the 1293 blocks to 71.12mm whereas MEGA pistons are 71.06mm nominally. Talk about confusing.. 0.06mm is 2.3622 thou. website:- http://www.terryhunt.co.uk
31st Jan, 2008 at 10:11:21pm
Bore size stated in documantation is usualy the piston major diameter plus the maximum clearance, so a 1275 standard bore of 70.625mm on minimum clearance, isnt 70.625mm.
31st Jan, 2008 at 10:13:14pm
From Haynes manual
31st Jan, 2008 at 10:29:22pm
The Haynes say different things depending on which (Metro/Mini) and which colour Haynes it is, but it's really the bottom skirt clearance that matters on a rebore/hone as the way the piston has been machined will determine the top clearance.
31st Jan, 2008 at 10:32:01pm
Also bare in mind that pistons are not cylindrical.
31st Jan, 2008 at 10:34:06pm
Oh, and I've told them to offset the bores by 0.25mm (0.010") outwards to reduce the risk of getting back a scrap block.
31st Jan, 2008 at 10:39:27pm
Also bare in mind that pistons are not cylindrical. EDIT: Although I think most people here probably knew that anyway. Absolutely, nor are they parallel top to bottom (which I'm sure most here also know), which is why I always ask for (and sought advice on) bottom skirt clearance, which I always take to be thrust plane (90 degrees to crank). Schrödinger's cat - so which one am I ??? |
1st Feb, 2008 at 07:37:14am
I use 0.06mm which is near 25 thou. Seems to work. FOr instance, I bore the 1293 blocks to 71.12mm whereas MEGA pistons are 71.06mm nominally. Talk about confusing.. 0.06mm is 2.3622 thou. Yeah yeah I got it almost right :) On 13th Jul, 2012 Ben H said:
