Home > Help Needed / General Tech Chat > Clutch problems, anyone ever had play in their pedal??
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Ive had clutch problems forever, i always have to press the pedal right to the floor to get it to work.
This week i set out to sort it out. I changed the seals on the master cylinder, which were fine anyway, i changed the clutch slave, and the pipe. I adjusted the clutch wok nut perfect as per turbodaves guide, but its still rubbish! Still no difference! Im bleeding it right, and everything shoudl be fine.
all i can put it down to is that there is loads of play in the clutch pedal! Does anyone know what causes this? the master cylidner is only about 4000 miles old, and the seals are brand new now, what causes the play in it?
Ive bought another pin arm (the rod thing that goes into the clutch slave) should i weld an extension onto it?
thanks everyone!
Nick
Member #: 154
Midlands
check for wear on the clevis pins, check for wear on the ball on the end of the clutch arm (if thats gone best to replace the plunger too)
if you still have no joy either make a longer slave push rod or stick a nut on the end of it, usually only have to do that in extreme cases though ie if you cant get enough throw to disengage it at all.
^^ what he said. My money is on play in the plunger and arm
what they said^^
to be sure i'd recomend getting a new pin that goes into the slave, and a new clutch arm.
I presume this is a preverto setup?
adjust it with out the spring on the slave, pull the clutch arm out to take any slack up then wind the stop bolt out til it touches the arm and then back a flat and lock it up, then put the spring on.
I think its also worth having a braided hose from the master cylinder to the slave too.
inspect the clutch pedal clevis pin hole for wear too, on my mk1 it was worn to fuck, i driled oit out bigger and sleeved it with a bit of brass.
jamesfawcett
Member #: 218
Thanks everyone, ill order the plunger and arm, and also a clevis pin (hate doing the R clips!!) and ill replace the whole lot
cheers!
james
On 2nd Feb, 2008 feebleuk said:
a clevis pin
There are three clevis pins, and they all wear so you're best of replacing the lot.
jamesfawcett
Member #: 218
Hi everyone,
It was all down to wear in the parts,
The clevis pin at the top of the pedal was badly grooved, so replaced this.
Replaced all the others, too in the engine bay, but the ball on the end of the short arm was also worn badly.
Ive ordered a new one, but until it comes rather than extend the pin by welding onto the end a brake union fit perfect. It acts like a sleeve over the end of the pin, doesnt move about and extends it just slightly. A quick working bodge!
So for now, i can get all gears no problem, then when the new arm comes ill replace all the parts!
I love this picture:
is that one of carls lightweight cranks?
