Home > Help Needed / General Tech Chat > MPI fuel filter
chedds
Member #: 2249
Hello! Have just come into possesion of a 98 Paul Smith mini so here is the first of possibly many questions. (I normally tinker with old series land rovers).
Where is the fuel filter!? Can't find it at all, I believe it supposed to be in the boot..do I have to remove the fuel tank to get to it cos I can't see it anywhere else.
Also how many grease nipples are there on these cars?
Cheers for any info! *smiley*
The fuel filter is bolted to the rear subframe underneath the fuel tank.
You should be able to see it by your rear silencer.
Edited by minimole23 on 6th Feb, 2008.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Nips- top and bottom ball joint on front hubs, top suspension arms on the front and rear radius arms infont of rear wheels. Whats that 8?
On 7th Nov, 2008 Nic said:
naeJ
m
chedds
Member #: 2249
That's a great help, cheers
