Home > Help Needed / General Tech Chat > carb leaking!!
timboc
Member #: 2043
Hi, any one ever had any problems with there turbo carbs leaking the dash pot oil inside the carb??? tis a weird one i rekon!
cheers tim
T3Tone
Member #: 252
Sunny suffolk
Have you filled the oil to the brim or just to the top of the pluger housing in the piston?
-MINI CLUBMAN 1380 TURBO-
turbo hogster
Member #: 178
stowmaket suffolk
you only need enough oil so the plunger has 1 inch between the black cap and the top of the carb any more and it will use it up
MarkGTT
Member #: 1194
Shropshire.
im having the same issue.. the carb is leaking the dashpot oil from the bottom of the piston.
i fill the correct amount in, take it for a short dive and it quickly leans off, get it back and sure enough the oil has gone..
What will cause this?
