| Home > Help Needed / General Tech Chat > Quick Question Engine Block | |||||||
332 Posts Member #: 483 Senior Member Merthyr Tydfil |
8th Feb, 2008 at 03:26:05pm
Quick Question Ive had piston trouble and need my block overbored I do not have the funds. The engine is 1989 standard 1275 turbo.
8th Feb, 2008 at 03:37:29pm
No, everything is similar, just check that it is infact 1983 and not form 1981. Then it will be an A series. They're still interchangeable, just check that the drop gears are the same. On 13th Jul, 2012 Ben H said:
8th Feb, 2008 at 03:42:39pm
Can I tell from the number on the block what year its from. I bought the engine out of the car so basically it could be any year. It had single spring valves in the head I thought maybe thats the older turbo. |
8th Feb, 2008 at 04:03:15pm
I thought that all Metro turbos had double valve springs as standard?
Edited by theoneeyedlizard on 8th Feb, 2008. In the 13's at last!.. Just |
8th Feb, 2008 at 04:12:48pm
it came attached to the engine I had it cheap for spares. My 1989 turbo has double valve springs.
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
9th Feb, 2008 at 05:29:31pm
The engine number and either a Metro Haynes manual or some Metro microfiches should give you a good idea of age. Metric is for people who can't do fractions. |
