| Home > Help Needed / General Tech Chat > stock fuel pump and HIF 44 limits, odd problems on dyno ( NA sorry) | |||||||
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
8th Feb, 2008 at 08:26:00pm
Edited by Sir Yun on 8th Feb, 2008. That sir, is not rust, it is the progressive mass reduction system
9th Feb, 2008 at 12:03:51am
I've seen std unmodified Hif44s deliver over 100hp on a Norwegian "strict" dyno. Shouldn't be a problem. On 13th Jul, 2012 Ben H said:
9th Feb, 2008 at 01:49:54am
Unfortunately, you cannot compare booster power figures to n/a power figures using the same carburettor.
9th Feb, 2008 at 05:08:15am
well i would say i dont know the spec of the 13 cam, but depending on the rollers about 90 bhp at the flywheel would be about right for that spec.
9th Feb, 2008 at 08:26:00am
see if the choke seals are leaking ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
9th Feb, 2008 at 08:53:15am
On 9th Feb, 2008 stevieturbo said:
Unfortunately, you cannot compare booster power figures to n/a power figures using the same carburettor. I'm talking N/A in this case.. On 13th Jul, 2012 Ben H said:
9th Feb, 2008 at 11:11:17am
is the mechanical pump in good condition? surely this must be around the limit for one?
9th Feb, 2008 at 02:32:56pm
thanks for the input blokes :)
Edited by Sir Yun on 31st Mar, 2008. That sir, is not rust, it is the progressive mass reduction system
