| Home > General Chat > Seedo drive gears | |||||||
![]() 399 Posts Member #: 793 Senior Member Milton Keynes |
10th Feb, 2008 at 11:31:12am
Could anyone tell me what dpeedo drive gears should be used ( the number of teeth on each cog) for a standard turbo box with 3.1 final drive on 13" http://i28.photobucket.com/albums/c248/spe...er1/mini007.jpg
10th Feb, 2008 at 11:40:16am
As long as the tyre rolling radius is not significantly different from the 145/70/12, then the standard set will do.
10th Feb, 2008 at 12:37:41pm
i have given up with speedo's now and just use a satnav, my last box has a 1275gt speedo drive the current box i have is a mg metro unit but its horribly out at 40 im doing about 55mph =/. atleast with the 1275 box it under read Drives
10th Feb, 2008 at 01:14:46pm
im using 6/16 gears gavin ,thats on a 3.1 and 165/60 12 tyres ,reads 2 mph slow at 70 apparently .
10th Feb, 2008 at 01:55:27pm
You need to know the turns per mile of your speedo, if its the old center binacle type, it will be marked just under the odometer, just to the right. If its the later behind the wheel speedos, you need to diss assemble the speedo to get to the mechanism and the turns per mile is marked on the coloured plastic spindle gear on the speedo mechanism itself.
Edited by Sprocket on 10th Feb, 2008. On 26th Oct, 2004 TurboDave16v said:
10th Feb, 2008 at 03:39:15pm
Try this web link Gav, it allows you to input tyre size and speedo type and then you can work out what drive gears you need.
10th Feb, 2008 at 05:43:09pm
Ive seen that link before, but there are still an awful lot of drive gear combinations missing, for instance, 3.74 FD with a 1300TPM speedo needs either 15/5 or 18/6 drive gears and niether of those are listed.
10th Feb, 2008 at 07:02:41pm
Cheer's chaps ! but on reading you're responses it's dorned on me that I'm using a 100mm Dia 120 mph Smiths speedo (I think from a Dolimite). On inspection of the speedo the only numbers I can find is on a little sticker on the inside 245-32, so any ideas what this denotes ? I'm uising 175/50/13 tyre's with a 3.1 diff. The best I've come up with is 7/17. http://i28.photobucket.com/albums/c248/spe...er1/mini007.jpg
