| Home > 998cc > A Series A+ Interchangability | |||||||
11th Feb, 2008 at 05:33:47pm
I've been offered another 998 lump but this one is an A-Series, which is good in some ways and it means I've got all the bit's for a pre-vertro clutch but I was wandering what other parts are interchangeable with the A+ engines as I'd like to use the best bits from the various 998s I acquired to build my turbo lump. Isambard Kingdom Brunel said:
11th Feb, 2008 at 05:44:21pm
Everything! On 13th Jul, 2012 Ben H said:
11th Feb, 2008 at 05:55:30pm
The A+ rods are better and the larger drop gear bearings, but other than that pretty much the same. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
11th Feb, 2008 at 06:08:40pm
12th Feb, 2008 at 07:44:28am
isnt the dizzy different? I know it is on large bores. |
12th Feb, 2008 at 01:20:45pm
On 11th Feb, 2008 wil_h said:
The A+ rods are better and the larger drop gear bearings, but other than that pretty much the same. I've never seen a small bore A+ rod in the flesh, what's better? The fact that the rods are not fully floating
Yes, the dizzy is different, but it's just a matter of using the one belonging to the block. On 13th Jul, 2012 Ben H said:
12th Feb, 2008 at 01:38:39pm
Isnt the timing plate and casing different? One accepts a Tensioner one doesnt. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
