| Home > Beginners Tech > getting ready for the turbo set up | |||||||
4 Posts Member #: 2242 Junior Member NY(college)+CT(home), USA |
13th Feb, 2008 at 04:38:28am
So I picked up my mini and found the turbo and manifold that i had upstairs in my garage. I'm hoping some of you guys out there can help with out with where its from. I am guessing that i will also have to install a box in the firewall before i can set it up. The engine is a 1360, with stage II head? Also i took the carb of the motor, the code on it says:
getting back into minis, cause people with big cars are just compensating for something... |
13th Feb, 2008 at 11:36:20am
yes you can rebuild it and run it on the car with no turbo ,but the needle and spring wont be likely to be right for a nat asp engine ,so you may find it best to stick in the spring and needle from a nat asp engine for the moment . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
13th Feb, 2008 at 12:21:05pm
I think that the carb pictured above is a HIF38.
48 Posts Member #: 1748 Member Forum Graffiti<br><br>Queensland<br>Australia |
13th Feb, 2008 at 12:57:07pm
What's involved with boost-proofing an SU? I'm wondering as turbo HIF's are rare around these parts... A few seals here and there? Are there any key differences between the NA and turbo version apart from that? |
13th Feb, 2008 at 01:39:24pm
iv seen it work to blow through a normal hif carb , but you do get a little leakage from the spindle , it wasnt anything to worry about though , prob depends on how worn they are . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
13th Feb, 2008 at 02:43:23pm
HAHA
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
13th Feb, 2008 at 05:35:27pm
- that was a little odd....
15th Feb, 2008 at 03:14:50am
thanks for the comments back, can anyone tell me for sure what the turbo setup is from? will i need to put a box it the firewall? and how do i know the difference between the 38 and the 44? getting back into minis, cause people with big cars are just compensating for something... |
15th Feb, 2008 at 08:12:42am
The turbo is definately Metro turbo, the carb looks like a standard non-turbo item.
15th Feb, 2008 at 03:08:57pm
You seem to be missing the oil feed pipe from the turbo not a problem as you will no doubt be fitting the braded hose upgrade ki. Also the the acctuator seems to be missing the pressure feed pipe that supplies the controling force for the waste gate.
Edited by Mr Joshua on 15th Feb, 2008. Own the day
15th Feb, 2008 at 05:25:22pm
whats the history of the turbo setup?
