Home > Help Needed / General Tech Chat > radiator opions
Carl
Member #: 95
liverpool-on-sea
need some opinions please guys, i know ill probably have to suck and see but thought id ask.
on my toyota starlet 1.3 turbo conversion i was planning on using one of the half size honda rads but it may not fit :( so i was thinking of using either a two core mini rad mounted forwards or a front mounted injection one.
do people think theyll be up to cooling my toyota engine?
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Only one way to see.
I think the problem with the mini setup was the water pump as Nic has been looking into.
Suppose someone on here can do an effiecieny calculation for it?
the mpi front mount may be up to the job, id rather use that than a regular mini rad
What about the cinquecento one? matty uses that and it doesnt look too bad or too big
Jordan
Member #: 1392
I did tell carl that. My one is tiny. Rad on me cinquecento that is *blush*
Don't Hythe do an uprated MPI one?
Carl
Member #: 95
liverpool-on-sea
just had a lokk on there website would probably be up to the job but will cost me 235 quid to find out:(
cant fit a full size front mounted rad in because the turbo is half an inch from the front, so was planning on the honda rad infront of the gearbox but not got enough space the mpi rad should fit nice but not sure if there upto the job but there so expensive.
hmmmm
nova 1.0L rad is the same tube hight and thicknes core but is another half to 3/4 longer compared to an MPi rad
Edited by Sprocket on 17th Feb, 2008.
a chento rad is a good option, they are about 60 quid new.
evolotion
Member #: 83
Glasgow, Scotland
K10 micra alloy rad cools my engien fine.. very small too.
Denis O'Brien.
Double_Wax
Member #: 2250
Stockport Manchester
Have you read the latest Mini Mag with the Polo engine?
Rad tucked up in the rear subrame.
Carl
Member #: 95
liverpool-on-sea
lots of troulbe doing that really.
Double_Wax
Member #: 2250
It is, plus problems with slow speed and traffic not allowing air cooling, plus speed bumps. But its still an option.
What about a Golf Mk2 rad? Seen them used on Mini7's.
Nick
Member #: 154
Midlands
just replied to your post over on MF wrt the size of the mpi rads dude. i've got one here with a split core that you're welcome to borrow for mock ups if you want it?
Carl
Member #: 95
liverpool-on-sea
cheers bud after a day of searching, measuring and making cardbord radiators (dont think theyll hold water tho) i think im gonna av to go with a normal mini 2 core rad but front mounted. it fits just and ill see how it goes.
From a heat capacity point of view the MS 2-core rad will be more than up to the job (considering what power you are expecting.
It'll look a bit weird stuck at the front though.
renault clio ones are quite small and slim too, might be worth a gander in the yard of scraps
