| Home > Help Needed / General Tech Chat > pistons? | |||||||
11th Jul, 2004 at 04:29:33pm
just found these on minispares website http://www.minispares.com/web/Item/P21251%2D00/InvDetail.cfm do you reckon they'd be suitable for a turbo engine? one of the rings has gone on my engine and seeing as i cant afford a full rebuild just yet will these do to replace the ones ive got in there seeing as they give 8.8cr? On 20th Oct, 2015 Tom Fenton said:
62 Posts Member #: 198 Advanced Member |
11th Jul, 2004 at 04:56:47pm
They aint a very good for alot of power put it that way, theres a reason theyre cheap |
11th Jul, 2004 at 05:12:37pm
They dont have a very large dish and achieve low compression by having a shorter distance between the gudgeon pin and the top of the piston, fitted in a normal 1275 they are a few mm down the bore at top dead centre. Not good for squish, making them more suseptable to detonation. Id say theyre ok to around 100 brake, Mine lasted along time with 90hp naturally aspirated but with 130 bhp one broke.
11th Jul, 2004 at 05:49:02pm
i might give them a try then, as long as they last me untill i've saved enough money to get a decent engine built up anyway. plus i'm only running 4.5psi on a standard engine so i'm lucky if i'm touching anywhere near 75bhp.
11th Jul, 2004 at 07:15:12pm
I recon theyd last along time with that sort of power, they'll be fine |
11th Jul, 2004 at 07:48:00pm
cool, cheers for the info dude. is there anything else thats fairly cheap worth replacing while i have it in pieces? or what parts other than gaskets are a must to replace? On 20th Oct, 2015 Tom Fenton said:
11th Jul, 2004 at 09:54:26pm
worn out bits. Diff pin is one thing id change, otherwise just tierd parts. If it aint broke!
12th Jul, 2004 at 09:12:50am
Before you order ask if they have a slot or holes behind the oil control ring.
12th Jul, 2004 at 09:36:46am
Arent these +40?
12th Jul, 2004 at 10:04:34am
Just dont rev them!
AlexF |
15th Aug, 2007 at 01:53:51pm
On 12th of Jul, 2004 at 09:12am TurboDave said:
Before you order ask if they have a slot or holes behind the oil control ring. If slot, fine, but don't ever go over 5500 rpm or 100hp! They do indeed have slots. On 13th Jul, 2012 Ben H said:
15th Aug, 2007 at 02:08:14pm
15th Aug, 2007 at 02:19:31pm
I ain't the chief fer nuthin! On 13th Jul, 2012 Ben H said:
15th Aug, 2007 at 04:42:41pm
PMSL.. Edited by matty on 15th Aug, 2007. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
15th Aug, 2007 at 05:00:21pm
i love the way Vegard responded to the question like it was asked today |
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
15th Aug, 2007 at 07:05:00pm
Before you order ask if they have a slot or holes behind the oil control ring. If slot, fine, but don't ever go over 5500 rpm or 100hp! Oops, At avon my needle went off the counter running std everythink. I went way over 5500rpm put it that way. Back once again like a renegade master |
15th Aug, 2007 at 09:36:26pm
I read some where that the standard Rover A+ piston was good for 8500rpm as long as they are replaced frequently, and that was on Miglia builds, slots and all.
Edited by Sprocket on 15th Aug, 2007. On 26th Oct, 2004 TurboDave16v said:
100 Posts Member #: 745 Advanced Member Northampton |
15th Aug, 2007 at 10:31:09pm
21251 pistons aint the greatest: they were fitted into marina vans and such like and designed for low compression 'shopping trolly' work (not a great deal of strength in them)..
Edited by icklemini on 15th Aug, 2007. |
15th Aug, 2007 at 10:33:42pm
dave, this threads about 3 years old dude On 20th Oct, 2015 Tom Fenton said:
15th Aug, 2007 at 10:36:52pm
Vegard having a flashback?? :s
15th Aug, 2007 at 10:40:41pm
yup, vegard is the chief ancient post excavator On 20th Oct, 2015 Tom Fenton said:
15th Aug, 2007 at 11:15:12pm
Devastated was I
