| Home > General Chat > Bollox! its all gone horribly wrong... | |||||||
![]() 265 Posts Member #: 68 Senior Member Coventry |
12th Jul, 2004 at 05:17:25pm
Dont look like im going to be at Avon after all... i seem to have developed the mother of all oil leaks.... Sooperdooperturbocooperexpertengineering! |
Site Admin 6303 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
12th Jul, 2004 at 07:33:52pm
:( that really sucks mate. |
260 Posts Member #: 239 Senior Member Somerset |
12th Jul, 2004 at 08:01:39pm
Sounds kinda like you have the same luck as tend to have. Bad news and bieng on lates dont help matters either. Cheers, Stevo |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
12th Jul, 2004 at 08:54:28pm
2ft by 5ft ???
12th Jul, 2004 at 08:58:25pm
About a week! its gone from MAX to just above MIN... seems worse if you run it.
12th Jul, 2004 at 09:05:40pm
anyone know of any of them 'stop leak' formulas that the turbo wont mind drinkin? STP!??!?
12th Jul, 2004 at 09:10:37pm
thats really bad news :( Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
12th Jul, 2004 at 09:13:21pm
are you sure its the selector seal i know they leak but if there new shouldnt be that bad. just an idea its not leaking from some where else on running down?? maybe turbo pipe or summit
12th Jul, 2004 at 09:14:37pm
seems like its coming out the ends too! transfer case etc... Sooperdooperturbocooperexpertengineering! |
12th Jul, 2004 at 09:22:57pm
get the car up in air even axle stands , clean back of diff housing etc , use brake cleaner , and find out where its coming from cos thats a hell of a lot of oil !! Everyone knows that instructions only have to be read if the thing doesn't work....
13th Jul, 2004 at 07:25:07am
yeah, if you say its worse when its running maybe the turbo oil drain has split? Just a thought as it chucks out a lot of oil, infact a suprising amount!! |
13th Jul, 2004 at 10:45:11am
yeah, mine emptied almost the WHOLE engine Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
13th Jul, 2004 at 10:59:46am
Another way to get round leaks temporary is to use some red hermatite along the joint thats leaking. bit of a bodge but works the same! then schedule gasket changes when they're more convienent. |
