Home > Help Needed / General Tech Chat > Turbo pipe help. 1st time install.
JordieNE
Member #: 1591
Prudhoe, Newcastle
Hello all.
Right, the turbo engine is in and on its engine mounts. Woooo i say. Then i realize, i haven't a clue where some of the pipes go. so here i am seeking your knowledge.
1)
Sorry for the bad pic. Its the turbo actuator. Theres a small pipe coming from it, which loops round to the top of it. At this point, there seems to be a T-piece and theres another pipe coming off it. Where does the other pipe go, its just hanging.
2)
Is this used for anything? I aren't running a servo, so was just gonna blank them both off, unless you can get blanking bolts to fit the manifold?
3)
Can anyone help on the above?
Red txt says - fuel pipes? inlet / outlet? which is which?
Blue txt says - pipe is blocked off, is it supposed to be.
Yellow txt says - this is the end of the pipe from #1 (coming from the T piece on the actuator)
green txt says - the pipe is connected to the inlet manifold. should it be and whats it for.
Cheers all
Jordie
Edited by JordieNE on 25th Feb, 2008.
bawbee
Member #: 191
Falkirk, Scotland.
If you search for a thread on this, there are various good diagrams/photos available.
1] The actuator should be connected to the compressor housing of the Turbo. If it's the Metro Turbo then there will be a brass fitting with two ends on it, join one to the actuator, the other can be blocked off, have a bleed valve connected to it, or is connected to the ECU if you're using this.
2] The servo connection can be removed if you're not using it & the manifold hole blanked off, or a connection for a boost gauge etc fitted.
3] Carb connections - http://www.turbo-mini.com/59247/index.html
Jordie
Member #: 480
Cheers phil.
Is the compressor housing just above the actuator on the turbo? If so the pipe connects there and another piece comes off. if thats the right pipe, then i will just block the end as you said.
Thanks
