| Home > Help Needed / General Tech Chat > Clutch Drag | |||||||
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
29th Feb, 2008 at 01:35:28pm
So, my mini is finally running and going in a straight line when booted. Had a good shakedown of it last weekend when all was well.
29th Feb, 2008 at 01:37:59pm
Bleed it, and check the stop thing with your feeler gauges (see the haynes bible)
Edited by Nic on 29th Feb, 2008. |
29th Feb, 2008 at 02:47:40pm
look on manchester minis website - under the tech stuff - for a clutch troubleshooter. That should help. On 17th Nov, 2014 Tom Fenton said:
29th Feb, 2008 at 08:50:38pm
On 29th Feb, 2008 Nic said:
Bleed it, and check the stop thing with your feeler gauges (see the haynes bible) If it comes back you may have some perished seals or something, this is your own fault as you should of been driving it years ago ![]() ![]() ![]() ![]() the throw out stop has nothing to do with dragging, its a safeguard to stop user jacking the clutch out, |
29th Feb, 2008 at 09:20:08pm
I think he is on about the return stop, the 1/4 UNF bolt that the arm sits back on. If this is not wound out enough then it can cause issues.
1st Mar, 2008 at 08:44:26am
not sure if this makes any difference, but it's still on a verto setup atm, but this will change at a later date...
1st Mar, 2008 at 08:15:36pm
bit of an update...
1st Mar, 2008 at 08:36:23pm
check all of the union thingys are tight
