Home > General Chat > Windmill!
http://www.youtube.com/watch?v=7nSB1SdVHqQ
Dont no what to say. Scary
Rick
i read somwhere that it was a new set of blades on he turbine, if you can slow it down you can see one fall off, which throws off the balance of it which concequentally hits the base and explodes
andygardner
Member #: 513
Sheffield
I think I read high winds/brake failure. Apparently there were technicians in it shortly before it went down but managed to scarper when it became apparent they weren't going to get it back under control.
Wow. Yep you usually feather the blades at high wind speeds to stop or slow it down. Obviously this system had failed.
It was obvious from the start it was spinning 10 times faster than you ever see them spinning.
