Home > General Chat > T2 manifold building
MajicMini
Member #: 72
Do any of you lot possibly have the dimensions of pipe used on the Mirage Manifold please?, only I have got a good supplier of steel who can sort me out the bits I need to knock up a few manifolds.
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
I would use the same diam as maniflow lcb manifold.
MajicMini
Member #: 72
Thanks.
I will probably make a few up when I get around to it, so if anybody wants a freebie manifold to test out then let me know.
fab
Member #: 100
Paris' suburb
I'm interested in your project as that's a while that I think that we can do a lot better than wh
fab
Member #: 100
Paris' suburb
??? the end:
than what is existing,
be carefull , the central pipe should be slightly larger than the two others , also , mild steel is better because it's less prone to crack, will your pipes will be mandrel bends?.
don"t allow the fourth and first cylinders to flow against each other, but accord them more like an Y
cheers
fab
fab
Member #: 100
Paris' suburb
a better idea :
mail me at fabrice5200@yahoo.fr
