Home > Technical Chat > Whats the best caster camber setup??
ROB1N
Member #: 664
South Wales (chepstow)
I have the Quaife ATB Diff whats the best setup cheers Rob
really depends on how softly the car is sprung , with the normal cones ,at ride height with a bit of movement , i think 1.5 neg camber is seen as normal , caster varies between 3 and 6 ,but most seem to set it at 4 to 5.5 depending on the weight of steering and how much torque steer thay want .
