Home > Help Needed / General Tech Chat > 3pin turbo dizzy
JordieNE
Member #: 1591
Prudhoe, Newcastle
Picked up a 3pin later turbo dizzy (module on side).
The guy didnt have the bit of loom, so i need to know what the 3 pins do and where to connect them.
For reference, lets say the module is on the right, so the 3 pins are below one another.
Thanks
Jordie
shane
Member #: 1246
Lowestoft, Suffolk.
Believe its the two outer ones to the + - on the coil, not sure if polarity is an issue tho?
Shane.
steveobennet
Member #: 1657
wirral
with the module on the right the original wire colours are white/yellow top pin and white/black bottom pin. i think the white and black went to the negative side of the coil but i'm not sure. with teh white/yellow going to the posotive side.
On 15th of Apr, 2007 at 09:08pm Vegard said:
What the fuck is that on the rear of the car? One of the most stupid things I've ever seen. Rest looks nice.
10.5 psi no idea how many banannas
JordieNE
Member #: 1591
Prudhoe, Newcastle
Cheers guys.
