Home > Help Needed / General Tech Chat > standard metro turbo boost.what actuator?
welshdan
Member #: 1111
s wales
what boost can a standard metro turbo engine be run safely at? if i remove the standard metro turbo ecu, what acctuator should i be looking at? i was thinking about avonbar 8psi.is this any good?
Ive heard the Montego turbo actuators are set at 7psi. If you can find one mind, possibly a cheaper solution. Im unsure of max boost however.
welshdan
Member #: 1111
s wales
not sure il find one of those. is that the petrol turbo or turbo diesel ?
i used to run an rs turbo one,was quite nice.....
Petrol.
What boost did that set at.
Montego turbo was 10 psi. I had one I flogged to Carl.
8psi one would be fine. I have the standard one bled out to 7.5psi at the moment.
i think it may have 8psi or was it 12?
oh i forgot now,still have tho,
welshdan
Member #: 1111
s wales
my engine is a non mg metro block with swiftune sw5 cam, austin 1300gt head, centre strapped crank, duplex gears. it should be slightly better then standard mg metro turbo engine, but as its mainly standard parts i was wondering if around 8psi was suitable for this engine?want a nice useable engine, that will travel decent miles without problems (i will maintain properly).hopefully with have slightly more 'go' than a standard turbo engine.
Star Mag
Member #: 375
Leicestershire
I managed to get 11psi out of my standard metro one but was starting to spike so found another one with a stronger spring. Imo uprated actuators are a waste of money found a couple that can be made to fit for not much money!
evolotion
Member #: 83
Glasgow, Scotland
diesels are a good source of strong actuators, a standard 1.8 mondeo TD actuator opens at 1 bar for example :)
Denis O'Brien.
Cosworths use a T3, and have owners that freqently replace the standard actuator with a super duper one and sell on the standard one *wink*
redwing
Member #: 1574
Malta
Sorry to hijack the post (a little) but this was puzzling me recently too. On the standard actuator what is the highest bosst you could achieve using a bleed valve set up? I couldnt work out what the limiting item would be.
I run an 8psi actuator and can get over 20psi using a bleed valve. :)
redwing
Member #: 1574
Malta
Is that an uprated one Phil or the standard metty turbo?
Star Mag
Member #: 375
Leicestershire
Like i say have managed to get 11psi, but was spiking i dont know what other people have managed!
I managed 15psi on the standard one.
redwing
Member #: 1574
Malta
Thats good enough for me Lizard!! Thanks.
Careful of the box though. I learnt the hard way. It was great fun while it lasted though.
Not to mention a good excuse to upgrade everything.
mg-metro-matt
Member #: 1870
Aldershot (we are top of the league, say we are...)
im looking to run mine at 7.5psi
just a couple of questions are you using the standard BDD needle or a different one?
What spark plugs? mine currently has BPR6ES plugs in it at the mo but have read i should put cooler ones in.
thanks in advance
What do you guys mean by spiking?
redwing
Member #: 1574
Malta
IMHO BPR6ES is too cold. BPR7ES or even BPR8ES seems to be the norm here.
