Home > General Chat > Slow off the Mark!
1380turbo
Member #: 1211
Working up the BHP ladder.
Getting my mini upto 15mph is an ordeal.
Still running the turbo build in at the moment so not too concerned yet as it hasn't been fully set up, but just interested in any comment.
Getting it going quickly from a standing position is a real nightmare. Riding the clutch at 2500-3000 is about the only way i can get it to shoot off the line. Not sure if it is just cos of Turbo lag, a characteristic of the cam, the light flywheel or the ratio of 1st gear? Once its rolling and the turbo kicks in its like being hit by a train so all good there *tongue*
Does anybody else have similar problems?
Karl
What cam and rockers are you using?
What turbo?
What ignition system?
1380turbo
Member #: 1211
Cam - Avonbar Phase 2 with 1.3 roller rockers
Turbo - T3
Distributor type ignition with lumenition optronic upgrade. running 8 degrees BTDC @1500
Shouldn't be like that then. I was just worried that you had a 296 and 1.5 on as you'd end up with the driving experiance you describe.
I suspect it's all down to fuelling.
1380turbo
Member #: 1211
Could well be will. I hope so cos apart from that it drives lovely, maybe just needs richening up a smidge. cheers buddy
Get it on the rollers!!! You will be amazed with the difference.
How long before it's run in?
1380turbo
Member #: 1211
Done about 350 miles, so another oil change at 500 check the rockers and off to the rollers *laughing*
Yes i'm sure it's just a tune issue, as by reving it your getting the extra fuel into the engine.
yes off to the rollers ASAP
my monies on the fueling issues
madcatminis
Member #: 5327
Dudley, West mids
Sorry guys for digging up an old thread.
After having my car set up on the rollers two weeks ago I haven't used the car until today and it drives like a bag of crap.
After the set up it was awesome but today I'm getting all the pulling away problems in this thread.
Also when at full throttle it keeps popping through the inlet and to go past 50mph i have to keep blipping the gas pedal to build up momentum.
I haven't messed around with anything but I did check the ignition timing and it was really advanced at 1000rpm vac disconnected, around 12btdc. *oh well*
I thought that I could be ruuning to much boost as I'm using a cosworth actuator but I ain't pushed it hard enough for it to go past 15psi.
Since it's rebuild over christmas it's covered around 100miles.
I did put fresh fuel in today but it did'nt help.
I'm getting fed up messing around with it now. :(
mini_mad69
Member #: 7048
Bridgend
Edited by mini_mad69 on 22nd Feb, 2011.
Turbo parts collector at the moment, almost ready.
